anti-theft system
Old Jan 20, 2011 | 12:52 AM
nikwave's Avatar
nikwave
anti-theft system
im thinking in an ignition killer switch or some other system for my truck.i dont want to spend big bucks on an alarm system,so if you guys have experience on this matter please let me know,thanks!
Old Jan 20, 2011 | 10:08 AM
bad12jr's Avatar
bad12jr
Auto or standard. If its a standard you could put a toggle up under the dash and run in line with the clutch switch. Break the circuit and no start.
Old Jan 20, 2011 | 11:34 AM
redman84's Avatar
redman84
Or a chip with a no start setting and hide the ****.
...or a springfield
Old Jan 20, 2011 | 12:12 PM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Hidden toggle switch that intecepts one of the CPS wires.
Hidden switch that intercepts one of the starter wires, won't even turn over.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Jan 20, 2011 | 12:24 PM
Robbgt's Avatar
Robbgt
A large dog
Old Jan 21, 2011 | 04:29 PM
nikwave's Avatar
nikwave
whats the cps?i thought about the starter but this one is a manual transmission so i think you can push start it in second gear.i would like to spice in one of the computer wires,one with no to many amps .
Old Jan 21, 2011 | 04:35 PM
nikwave's Avatar
nikwave
i checked the clutch switch ,it has 4 wires,do you know which one could i splice into?thanks!
Old Jan 21, 2011 | 05:47 PM
bad12jr's Avatar
bad12jr
I don't remember. Someone who does will chime in. Don't wanna send you in the wrong direction.
Old Jan 21, 2011 | 06:41 PM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
CPS = Cam Position Sensor.
If you cut one of the wires, the computer won't get a signal and won't know how to fire the injectors. Basically.
It has 2 wires and is located on the lower front of the motor with it's wires going up to the top of the motor. Pretty easy to get to.
__________________
Old Jan 21, 2011 | 07:37 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
After reading and researching I think this is the best, a little expensive but worth it:
Cyclops Theft Avoidance Module
Old Jan 21, 2011 | 11:46 PM
madpogue's Avatar
madpogue
The two wires closer to the firewall are for the starter interrupt. So you can cut either one of them and put a switch in series.
Old Jan 22, 2011 | 12:02 AM
oldbird1965's Avatar
oldbird1965
Today I pulled into a yard sale to get some stuff loaded and the guy said to me, you can leave that rig parked with the keys in it and nobody would take it. I just said maybe so, then pointed at his 35' camper and told him I could pull three of them at the same time. He didn't say much after that!
Old Jan 22, 2011 | 07:09 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
That Cyclops is neat and all, but my switches are hidden and cost $5 - $10 to wire up.
__________________
Old Jan 22, 2011 | 08:23 AM
RRranch's Avatar
RRranch
I just discovered that if I leave my DIY high idle mod switch in the on position that it won't crank. I don't even get a click. I know I hooked it all up right and it works great.
Maybe it's screwing up the IVS signal that it wants to start?
Old Jan 22, 2011 | 09:21 AM
oldbird1965
I'll have to see if mine does that.
