First time I've logged into the V-10 Forum, but I've been a reader for about a year now. Awesome Forum. I've had my 05 V10 for about five months now and as soon as I got it I went through everything, plugs, fuel filter, trans fluid & filter's, oil & filter, front & rear diff's, transfer case change, air filter, cleaned MAF sensor and throttle body and changed all fluids to Royal Purple and AMS-Oil because I had both on the shelf. Truck ran outstanding then I added the 5-Star tuner after talking with Mike on the phone and the difference was night & day better than before. picked up a solid two more miles/gal just driving empty down the road and towing enclosed sled trailer's to the UP in the last month is also a dream. Best truck I've ever owned so far. After owning this truck I don't know why I didn't switch from my old 7.3L F250 to the 3-valve V10 a long time ago. My other truck is even tricked out with Gale Banks mods and it doesn't run as well as the V10. She uses a little more fuel, but its not drastic. My buddies 6.0L's have to be plugged in to get started from about the mid 20's on down and smoke like you're burning a pile of leaves. The V-10 on the other hand fires right up, no smoke, its quiet, and the heat kicks in about 5-7 minutes. I got the truck from Arizona and she was pretty clean and had never seen snow. I wheeled it out a couple times and shot Corrosion-X in the doors, tail gate, and up under the body seams and stripped the clear-coat off the rims and polished them a couple times thought I was done. Three weeks later I couldn't stand looking at the chassis and frame anymore so I pulled it in the garage, put it up on blocks and stripped the whole frame & chassis down and covered it with POR-15 base & Chassis Coat black. Now she looks new again. I may have some OCD going on, but I'm extremely happy with the new ride and the 87 Performance Tune from Mike. I haven't tried the 93+ Tune yet, but I'll be sure to throw my $.02 in. I'm sure I can hit the 300K mark like I did with my Power Stroke without any problem. I'll post some pics as soon as I get the chance.
Thanks for the welcome guy's! By the sounds and looks of it, I'm not the only one with a little issue..............LOL, My wife thinks I'm crazy and some buddies just say I have some issues or I'm not right. I just laugh. What else can I do I guess.
Well, I'm not an OCD type when it comes to body or frame, but I do qualify when I spend 3 hours with 200/600/1000/1500 grit wet sand paper to make a nice pretty finish on my axle stubs where they ride in the needle bearings
I'm picken up what you're layin down Krewat. I like to pretty meticulous with mechanical and electrical parts and fixtures as well. Its just good piece of mind.
