Modular V10 (6.8l)
anyone using E3 sparkplugs
Old Jan 19, 2011 | 02:05 PM
shore's Avatar
shore
My 2002 v10 is due for new sparkplugs. I was wondering if anyone here is using the new E3 sparkplugs. Are they all hype like the splitfire plugs were when they came out, or are the E3s worth buying. I bought a set of splitfires when the came out, and it was a waste of money. I was also thinking about buying some of those Accel silver sparkplugs, I saw those for sale on summitracings websight.
Last edited by shore; Jan 19, 2011 at 03:36 PM. Reason: Accel Silver plugs not motorcraft
Old Jan 19, 2011 | 03:37 PM
Future_LEO's Avatar
Future_LEO
Stick with Motorcraft
Old Jan 19, 2011 | 06:45 PM
dkf's Avatar
dkf
Waste of money, just like the Splitfires. Motorcraft or Autolite plugs work the best.
Old Jan 19, 2011 | 06:54 PM
KOESTNER's Avatar
KOESTNER
Like dkf said, Motorcraft or Autolite. Any other brand is a waste of money.
Old Jan 20, 2011 | 10:46 AM
onug's Avatar
onug
I did some recon on those plugs a few months ago. They don't seem to be better, and many posts I found said they didn't last very long.
Old Jan 20, 2011 | 01:46 PM
dkf's Avatar
dkf
They are made in China also. (At least the small engine plug I bought to try was)
Old Jan 20, 2011 | 10:46 PM
mudfuel06's Avatar
mudfuel06
I had them on a Craparado that I had and I will swear up and down they made a slight difference in mpg's. Was it worth the cost, dunno because they were in there when I bought the truck, but when I put new and different ones in, I got about a .5 less per gallon, hand calculated.
Old Jan 21, 2011 | 04:25 AM
SKI-V10's Avatar
SKI-V10
Read the thread "sad V10 owner". I think I would stick to Motorcraft. I think you need to match heat range right in this truck or **** happens.
Old Jan 21, 2011 | 04:33 PM
shore's Avatar
shore
Thanks for the replies. Basically, what you're telling me, is to stick with Motorcraft? Ive always had good luck with Accel Plugs in my 460s and 390s. But with the v10 I own, I think I'll stick to Motorcraft.
Old Jan 21, 2011 | 07:07 PM
Fordfanatic4life's Avatar
Fordfanatic4life
motorcraft or nothing..
the back plugs are hard enuf to change you DONT wanna have to go back in there later...
Old Jan 24, 2011 | 06:35 PM
mwsF250's Avatar
mwsF250
The ignition system in these is strong enough to work perfectly well with just about any plug.
Motorcrafts are extremely reliable, inexpensive, readily available. Perfect.
ANY "snakeoil" plug will perform better if you use them to replace seriously worn out plugs. Heck, that's how the marketing slimebal....errr.... experts arrange for those neat numbers to use in the ads.
Replace a good motorcraft with snakeoil plug? I GUARANTEE you will NOT see any repeatable positive improvements.
Iridium or double platinum (on both electrodes) will last longer without maintenance, but I change ANY steel plugs in aluminum heads at 50K miles anyways to avoid thread seizures.
ptt
30
Aug 25, 2017 10:11 PM
Gangly
Mar 18, 2015 09:39 AM
georgiaboy79
1997 - 2003 F150
Sep 9, 2014 09:11 AM
toeout
Modular V8 (4.6L, 5.4L)
Jan 20, 2013 08:12 PM
Pantera-nm
Apr 13, 2005 02:24 PM
