Restoman2's 351w try to start count
Any and all help is appreciated. I broke my one rule about toys twice in 3 years. I bought something that did not run. So I bought a truck with a blown head gasket, bad idea.
1991
F250
4x4 TTB
Single cab long bed
351W
The guy said he drove the car 100 miles every day to get to work until the head gasket blew. He also said that he pull over right away and turned it off and got towed home. The back left piston had coolant sitting on it and evidence of where the gasket had blown. He removed his beloved muffler and placed the ad on CList. I cam in and removed the heads and had them worked back to stock plus 5 broken bolts removed plus the rear crossover tube plugged. The lifters were shot so they were also replaced, but awfully tight to install. Mistakenly I did not point the distributor in any specific direction before removing. When assembly began I put the #1 piston up and pointed the dist to #1. If all else fails I can clock it 180 deg and start over. I still have a few vacuum lines to sort out , but nothing critical at least from what I can tell to hamper a start up test. All undecided ports were plugged so that no vac leaks occured. I go to start and 1 it's hard to start 2 it sounds like a rod is being slug around (all pistons are attached) but that's what it sounded like. I'm going to remove the belt and see if I can get a little help. The coil was disconnected the first few cranks just to get oil up and about. What could I be missing.
1991
F250
4x4 TTB
Single cab long bed
351W
Having the timing way off will make an engine very hard to turn over. I agree with deeznuts822 that you have a timing issue. When you had your heads off did you rotate the crank to check the rotating assembly and check all cylinders for any damage? Something like a bent rod may have shown up at this time. I would play with the timing some more before I write off the motor. Pull the plugs and put a socket on the crank and turn the motor over by hand and see if you can feel any binding when you rotate the crank. If there is noticeable resistance anywhere in the rotation you may have some internal engine damage.
riggz
10-01-2007 08:01 PM
nminer1
04-19-2005 10:28 AM
mcguyver
09-09-2002 08:51 AM
