What Next?
Old Jan 18, 2011 | 08:23 PM
GMANXXX's Avatar
GMANXXX
What Next?
I have an 06 F-250 6.0l with 110k miles blowing clouds of white smoke at idle and on acceleration. No codes or other issues.
I had ARP studs installed, BD diesel egr delete kit, stock oil cooler replacement and installed a coolant filter a month ago to correct the problem(and add a more aggressive tume!)
What can I do/add/check before taking it back to the shop?
Thank you for any advise you can offer!
MG
Old Jan 18, 2011 | 09:51 PM
bismic's Avatar
bismic
What does the white smoke smell like?
Old Jan 18, 2011 | 11:44 PM
mohle's Avatar
mohle
What Bismic said, and are you losing and coolant?
Old Jan 19, 2011 | 05:29 AM
adambomb's Avatar
adambomb
what they said^^^^^+
does the white smoke just keep blowing whenever you are driving or puff a big cloud when you take off from a start and then clear up?
Old Jan 19, 2011 | 01:04 PM
GMANXXX's Avatar
GMANXXX
The smoke smells like spent diesel, I don't detect the sweet smell of coolant. The coolant level seems to be holding steady, and always has. The smoke is bad sitting at a stop light, often enveloping me in a cloud, and at take off from a stop. I don't notice it while driving. The only other symptom seems to be a decrease in fuel mileage, to the tune of 2-4mpg.
Thank you for your interest.
Mg
Old Jan 19, 2011 | 01:06 PM
bismic's Avatar
bismic
Injector or FICM issue most likely. You can test the FICM voltage, but that isn't always a sure-fire test. After that, it would probably be worth taking it in IMO. You do not want to be driving it w/ it overfueling in one or more cylinders.
Old Jan 19, 2011 | 01:18 PM
ljutic ss's Avatar
ljutic ss
If you smell the oil on the dip stick you might smell diesel if it's over fueling that badly. A over fueling injector could lead to some very expensive repairs from the damage it causes. I would not delay in getting this repaired.
Old Jan 20, 2011 | 09:57 AM
GMANXXX's Avatar
GMANXXX
Thank you for your advise!
Your help is greatly appreciated.
Old Jan 23, 2011 | 07:07 PM
GMANXXX's Avatar
GMANXXX
Follow Up:
I took the advise given, and found a local tuner, He ran a full diagnostic; engine is running just fine. The turbo, on the other hand, is soon to be replaced!
Old Jan 23, 2011 | 07:14 PM
bismic's Avatar
bismic
Thanks for the follow up. Keep us informed when you get it repaired. BTW - the Garrett Powermax is a great aftermarket turbo.
Old Jan 24, 2011 | 08:19 PM
GMANXXX's Avatar
GMANXXX
I have a powermax on the way!
Thank You.
MG
Old Jan 24, 2011 | 08:22 PM
texans's Avatar
texans
I envy you!!! I hope to get one this year sometime!
Old Feb 1, 2011 | 08:23 PM
GMANXXX's Avatar
GMANXXX
I ordered on Monday, turbo arrived Thursday. I installed it Friday.
I have to give the PowerMax two big thumbs up! -Just not when driving, I have to hold on!
MG
