transmission question
Old Jan 19, 2011 | 10:09 AM
SpringerPop's Avatar
SpringerPop
Originally Posted by Joe28443
My guy said he would charge me 95 for the swap, filter and fluid, to me it does not sound bad but I will look at the website and see what I think
If you've got the extra money, and wish to avoid a messy afternoon, then I'd say this was a reasonably-priced way to get 'er done! He doesn't have the fear of the unknown that you do. Stick around and watch the process to get over that fear for next time.
But tell him that you insist he use an inch-pound torque wrench on ALL the bolts, including the pan bolts. It's important. Give him the values used in Guzzle's write-up.
Pop
Old Jan 19, 2011 | 10:15 AM
Joe28443's Avatar
Joe28443
Joe28443
Originally Posted by Brother Les
Anyone with a BTS and I would think, a JW has a one of these types of TCs. As you said in your first post about 'overkill'... if you are not 'pulling' some big stuff, yes, I think that you are going for 'overkill'.
Save your money for some other Mod.
I tow about 7k now and eventually no more than 9k. I am not replacing the tc until the tranny craps out
Old Jan 19, 2011 | 12:14 PM
aklim's Avatar
aklim
The problem with that sort of thinking is that as long as you keep it below "overkill" level, life is good. Now, what happens when you exceed it? I have bought "just enough" too many times and spent more later on when I would be money ahead of the game if I bought "overkill" the first time.
Old Jan 19, 2011 | 12:25 PM
Joe28443's Avatar
Joe28443
Joe28443
Well noted but but I am not a HP junkie, I don't drive my truck like I stole it, I will never be on a dyno and I will not hook over 9k to my bumper. A slightly modded stock tranny will probably be fine for me I just want it reliable for my needs
Old Jan 19, 2011 | 12:37 PM
aklim's Avatar
aklim
You are not YET, you mean. Read my sig. Originally, I bought a gas Yukon XL and wanted a shift kit and then an ECM tune. Went to a Powerstroke and swore that I would only get a tuner and maybe a VB. See what happened?
When my trans broke, I knew I needed a replacement. BTW, I don't think your truck should be hauling over 10K since that is the weight rating. I haul about that much with the RV and the ATVs in it. I went with a BTS because that is the only company I have read about that will allow me to mod the truck and keep the "forever" warranty. Everything breaks sooner or later. I spent more today so I wouldn't have to spend more tomorrow.
If you are dumping the truck ASAP, get whatever is cheapest since the new buyer won't give you squat for it. If you are keeping it for a few years and no mods, lifting the truck, etc, etc, IOW 100% stock, get a stock reman since they will warranty you for 3 years. I was plannign to mod the truck and keep it till it runs into the ground so I went with BTS. My warranty is up a year ago but I know that if I break it tomorrow, I send it in for a new rebuild. More expensive today since there is a "buy in" price. Tomorrow when problems arise, I save.
Old Jan 19, 2011 | 01:12 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by miller_feed
Here is another link that shows how to install the VB. Welcome to guzzle's BTS Valve Body Web Page
Argh! I didn't know Bob had that on his site. I'll have to remember it.
I did a quick Google search because I realized the instructions I have (that I was going to cut and paste) was for a Gen 2 Lightning. And even though the L's have the same 4R100 (just in a different trans case), the instructions might have confused the OP because it attacks the mod from a slightly different stand point.
Pop
Agreed. The fluid and filter would run you at least $50 to $55 bucks, more if you have to buy a torque wrench.
Stewart
Old Jan 19, 2011 | 03:28 PM
trackspeeder's Avatar
trackspeeder
Thanks for the post. When I talked to a tranny guy yesterday and told him what I wanted he asked why I was changing the vb, he said you sure its not the accumilator that you want changed? I said all I know is I got a vb that I need put in. Never heard of an accumilator, but then again I don't know much about anyway. My guy said he would charge me 95 for the swap, filter and fluid, to me it does not sound bad but I will lookat the website and see what I think
The part you are changing is the accumulator body.
Old Jan 19, 2011 | 03:33 PM
tritonman2001's Avatar
tritonman2001
Sorry about the hijack, but I cant find the number or web site to bts, and I would appreciate it if somebody could post up with the info.
Old Jan 19, 2011 | 03:36 PM
aklim's Avatar
aklim
870-422-3673. Brians Truck Shop
Ask to be on hold. Don't "take a message".
Old Jan 19, 2011 | 06:25 PM
big poppa's Avatar
big poppa
Got mine from here(different name now) but Clay sells them too now, heres what it looks like and here's where it goes Like Pop mentioned, torquing those bolts with the proper torque is the most important but otherwise, a easy install.
Old Jan 27, 2011 | 09:47 PM
Joe28443's Avatar
Joe28443
Joe28443
well I got it put in today. I can honestly stay in stock tune i really could not tell a difference. When it warmed up and i was able to put it in 60e and take off from a light i could tell the shifting was more crisp and i could tell the most from 2-3. Overall i like it and if it is helping my tranny last a little longer than its all good.
Joe28443
18
Dec 22, 2012 12:37 PM
Chipworkz
Apr 20, 2012 09:43 AM
quesey
Mar 8, 2012 10:23 AM
Oly-f250
Mar 10, 2011 05:33 PM
HighOctane
44
Jul 23, 2009 08:10 AM
