1978 - 1996 Big Bronco
tachometer problem
Old Jan 17, 2011 | 07:58 PM
FourXFord2's Avatar
FourXFord2
tachometer problem
The tachometer in my '91 is off, I noticed it right after I started driving it several weeks ago. I verified it with an inductive tach. At 2000 rpm actual the dash tach reads 3000. I verified that the cluster is for an 8 cylinder, tried another tach unit from different cluster with same results. I baffled at the moment, need more input. Any ideas?
Old Jan 17, 2011 | 08:06 PM
greystreak92's Avatar
greystreak92
The tach signal is driven by the PIP sensor and ICM wiring at the distributor. I don't have my wiring reference here at work so I can't give you anything more specific than that at the moment.
Old Jan 17, 2011 | 09:50 PM
FourXFord2's Avatar
FourXFord2
If you recall, I changed the ICM last month because of error code. No srvc engine light yet,but should check for continuos error codes, just because I can. There was no change in the tach function then till now, not elimanating it though.
Holmesuser01
Jun 28, 2014 11:41 AM
stydel311
23
Nov 20, 2013 08:17 AM
gumper 123
May 29, 2010 04:51 PM
02FordFx4
18
Mar 1, 2006 08:24 AM
dhag911
20
Aug 3, 2005 01:04 AM
