Anybody got a CB radio?
I have a Cobra 29 LTD CB and a Wilson 5 foot whip with a magnet base mounted on my roof. I found that is the best place on these trucks. Ford is notorious for having interference so I had to run my antenna wire from front to back. I mounted my CB on the roof and have the antenna running along the roof inside, down to a drain hole in the back corner of the cab, then up to the outside roof. I have about a 10 mile signal and on good days with atmospheric skip I can listen in to Georgia (from Ohio).
You can mount the antenna on your mirrors or whatever as well but like I said, the best place I found was the roof. I use a wire whip instead of one of those fiberglass ones you can buy. Big rigs are set up for it and they sit higher so it makes more sense in their case. If need be the Wilson antenna unscrews from the base so when you need to get into parking garages or something low, it takes a couple of seconds to remove the whip and it fits nicely along the back of the cab behind the seat.
I also got my CB at a truck stop as they usually sell stuff drivers may have turned in. The stuff works but it has been used. With some drivers there is this amazing power hunger and they always needs bigger and better. Personally for myself if I can hit a 5 mile span im good. I work on and drive trucks myself so I kinda know how it goes from both sides of it.
Actually the toolbox works but I actually use mine and I bought the clamp and everything for it and tried opening the box... Oops.. So I needed to move it. (I have the rail on my box so I didnt drill into the side of it)
Majority of people use the fiberglass whip which is fiberglass with a wire wound up around it and coated in a plastic. The wire antenna is a thin piece of stainless that uses an allen screw to set it in place. It basically picks up the signal in the base. Wilson sells 2 kinds: one with a rod you screw in with an allen as a lock and the only way to remove it is with the allen and one like I have where the base actually has a cap with the antenna that unscrews (more expensive)
Fiberglass: http://www.roadproonthego.com/store/...es/RPPS-3R.jpg
Wire: http://im3.ebidst.com/upload_big/4/5...31321-6105.jpg
Big rigs usually have the fiberglass but I like the Wire. But as I said, its all preference.
I have a 4ft firestick II, this is a fiberglass antenna with a tunable tip on the end of it. I use a cobra 19 (its a smaller version of the 19) and I can reach for probably 15 miles or if I can skip I can pick up stuff from maine (im in n). Course I used a SWR meter and tuned mine properly as well. The antenna is on the side of my toolbox.
Regardless of how cool it looks, stay away from a co-phased two antenna set up. Co-phased antennas need to be at least 1/4 wave apart, which is 9 feet on 11 meters, the CB band. Truckers can get away with that kind of set up because the trucks are wide enough with the mirrors they use. A production pick up won't be wide enough and performance will go down with a co-phased set up.
BTW, you don't want to get caught with a modded CB by the FCC. Yes, the chances of getting busted are pretty slim, but the fines start at $4000 and go up from there.
If you are putting out 100 watts on key down then you don't have a regular CB. You probably have one of the export models that has been outlawed by the FCC. I wouldn't go bragging about how many watts you are running on a public forum. Ya never know who's watching. As I said, the chances of getting caught are slim, but the fines start at $4000 and go up from there.
I ended up in a so called Cb War, where everyone wanted to walk on each other, show off, pretty much be idiots. Some actually would ride around town, antagonizing, and when the signal zero'ed in an antenna, they would rip it down. It got ugly. I finally said the hell with it, took my antron 99 down, never set up a home station again.
It was fun there for awhile, seeing how far you can reach out, but then they wanted to doctor thier systems and slam everyone with echo and BS.
