97 F250 Dana 60 work!!!???
Old Jan 17, 2011 | 06:00 PM
gt40racing's Avatar
gt40racing
Okay guys I am about to tackle the front end of my new truck. Has a dana 60 with leaking axle on the passenger side. Plan is to replace both inner and outer seals. Replace all the ball joints. Finish up with new disc rotors and pads. Is there anything else I should address while working the axle? Here is a update picture of my truck with my wheels off my 94....
Old Jan 17, 2011 | 06:25 PM
89ford73's Avatar
89ford73
big hammer lots of 2x4s the spindles can be such a pain in the butt to get loose, they get rusted up and almost grow together. when i did mine i cleaned all the rust off and put grease in there hoping next time i could actually get it apart. u cant hit where the bearing and threads are for the wheel bearings. i also used a large puller on the spindle nut to get mine off, not easy job. for me at least. good luck to u. no need to change the bearings in the front differential. they should be fine unless they got water damaged or something.
Old Jan 17, 2011 | 08:00 PM
Talyn's Avatar
Talyn
If you can get a slide hammer to do the spindles. do it.
Old Jan 17, 2011 | 08:47 PM
Dave Sponaugle's Avatar
Dave Sponaugle
I painted the mating surfaces with Never Sieze before it went back together.
I agree the spindle tubes off is the worst part.
Lots of PB Blaster in addition to the above mentioned tools helps get it loose.
Old Jan 17, 2011 | 09:07 PM
gt40racing's Avatar
gt40racing
Thanks guys.... I am making a list from your inputs and making sure I have everything before I dive into this project....
Radster
Dec 5, 2016 01:20 PM
-mywheels-
May 12, 2014 11:13 AM
Blue Rebel
16
Jan 12, 2014 10:00 AM
kilich
Mar 4, 2012 01:37 PM
88mmFlaK
May 23, 2007 12:23 PM
