Axle identification.
Old May 22, 2007 | 05:14 PM
88mmFlaK's Avatar
88mmFlaK
Greetings
I am replacing the ball joints on my '84 F-250 work truck, but for some reason the ID sticker inside the door is missing, and the serial number has been re-issued.
The folks at AutoBone need the GAWR for the front axle with regards to ordering the upper ball joints. I suspect I have a Dana-44HD , as the truck is not an extended cab. However, I cannot be sure it is not a Dana 50. It is a TTB, of course.
The legible info on the front axle tag reads thusly:
4.09 E3TA AGO
6 199-6
IIRC there are two applications: the 4600lb GAWR ball joint, and the 3800lb and lower GAWR ball joint. I am guessing the 4600lb axle is the Dana 60, and the 3800lb- encompasses the Dana 44HD and 50, am I correct? If so, then problem solved, as I know I do not have a Dana 60 in this vehicle --although I do have a 60 in the Klingon Warship, but that is a different rig ;p
Old May 22, 2007 | 06:02 PM
Mil1ion's Avatar
Mil1ion
Welcome to the site.
You need the 80-86 truck forum so I'll ask to have this thread moved for you.
Meanwhile I'll look it up
The numbers for 70's are different that the 80's
EDIT:
That stamping is actually
E3TA- AGC
it is a Dana 44 ...4.09 ...3850 lb axle
Your parts list is known as... 3AN
Upper BJ-E0TZ- 3049 A
Lower BJ - D3TZ-3030-A
Old May 22, 2007 | 06:09 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Split and Moved...enjoy FTE and all it offers.
Old May 22, 2007 | 06:33 PM
88mmFlaK's Avatar
88mmFlaK
Thumbs up
Thank you all for the warm welcome and the speedy reply with information!
cheers!
Old May 23, 2007 | 05:31 AM
IB Tim's Avatar
IB Tim
...And do not ever worry about posting in the wrong forum, as you get used to.... and use FTE more, it will all become second nature...so hang in there and just have fun.
Old May 23, 2007 | 06:36 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
EDIT:
E3TA- AGC
Lower BJ - D3TZ-3030-A THIS IS A TYPO ~ THE CORRECT NUMBER IS D3TZ-3050-A
Old May 23, 2007 | 12:23 PM
Mil1ion's Avatar
Mil1ion
Thanks Bill.
For trade:
One thick mis-guided Index finger that ocassionally make typos .... for a narrower one that won't
abranz
Dec 26, 2016 12:51 AM
LosOsos
May 25, 2016 03:01 PM
ChappyWagner
Jan 12, 2011 05:16 PM
MontanaMan
17
May 5, 2009 09:05 AM
bryan_johnson
Nov 4, 2007 05:44 PM
