So I have a question for those 7.3 lovers out there.
If you had $1000 and could only do 1 (maybe 2 mods if price was right) what would you choose?
I pull a 30' Camper during the summer and spring months for camping but otherwise play 'soccer dad' with 5 carseats/boosters.
I've looked at Dieselsite Adrenaline HPOP as an option ($600 there) or possible chip mods, exhaust, etc.
What would be your thoughts as the 'best' mods to make on a 7.3 2000 Ex? I'm getting 14 Avg right now between Freeway/Town driving with way to much idle time (pregnant wife, cold mornings = long idles....)
Lots of ppl list the mods they make but no real 'stepping' process as to which ones are often the best ones to do first.
Is it better to look at doing a chip mod before say the Dieselsite Adrenaline HPOP? Turbo fan replacement better than those? Etc.
Thanks for your help as I've been pouring over the Mods listed here and in the 7.3 section but still struggling to find a good 'progression' of mods for best over all performance.
Wait, what ?!? 5 car seats AND a pregnant wife ?!?
might I suggest the first mod be a vasectomy ?!? (just kidding of course ! bless you )
Hope you are on our side of the political spectrum as your family will swing elections !!!!
The top threethings I did on my 02 7.3 4x2 was
1)the responiveness I got from a low hp tuner....
2) the rear hellwig sway bar
3) a good flow thru muffler like the lifetime warranty on the Walker BTM - lower egt's by 200 degrees and nice sound...
With $1K, I'd do gauges, intake (6637), and exhaust (4" aluminized), and a DP tuner with a couple tunes.
That should leave you with money to have a T shirt made explaining why you now have Permagrin.
How is your rig when it comes to towing? Mine was ok when I first bought it, with a little wander, but over time it got worse. When we planned to step up from a 2-horse bumper pull to a 4-horse bumper pull, I knew I needed to upgrade the suspension for my family's safety.
If your suspension is good to go and you don't need to do the V code/B code (or any variation of) upgrade, then I'd look at doing performance mods.
The 7.3s like to breath, and the stock setup is fairly restrictive. Your first mods should always be opening up the intake and exhaust. After that, wringing more performance for acceleration and MPG are usually next.
So, for performance, the big three are intake (filter), exhaust, and custom tuned chip.
I like the AFE Big Boost filter for my intake, an MBRP 4" exhaust for my exhaust needs, and Jody at DP-Tuner for my custom tuning needs.
Gauges are always good especially if you tow, and you do, so I'd strongly, STRONGLY consider gauges. Exhaust temp, trans temp, and boost.
Why do you want an Adrenaline? Are you having problems with your HPOP? If yes, how was the problem diagnosed and how was the HPOP proven to be the culprit?
Save your money on the Adrenaline and get yourself either a modded pump from Joey or whatever aftermarket solution he has out. Learnt that one the hard way...
Rig is fine. Power seems good without any major issues but until weather gets better and I get somewhere like AR with some elevation (Texas = flat... and I grew up in CA in Sequoias, Grapevine Pass, Mt. Whitney, etc) I wont know for sure. Running a sway bar setup for the 30' camper and all seems good right now.
Probably my biggest thing here is not knowing if the suspension would need to be upgraded. Used to towing with my 2001 which isn't 4x4 and both ride different anyways due to slight lift in the 4x4. Any real 'tests' to verify suspension on my own?
Yeah I thought about doing the intake and exhaust. Exhaust seems like an easy fix on my own, intake, well a little more work but both did seem more recommended by people on the boards.
Stewart
Adrenaline was recommended by a buddy who swore by it, but I haven't had anything tested. He liked improved MPG and power he got but then again if he did have probs with it, then that would be why he saw such a great improvement on his.
Haven't done most of my truck work since I owned a 68 chev in HS and that's been almost 1/2 my life now
Appreciate the ideas and plan of actions as I pursue starting to mod this Ex out!
Hook you 4x4 up and take the trailer for a spin.
Both intake and exhaust are easy to replace. The exhaust is easier if you have a second set of hands helping with the downpipe.
There are a LOT of guys on the 'net who swear by the Adrenaline. But there are also those that post no difference between the Adrenaline and the stock HPOP.
This may not be accurate anymore, but the last time I checked, the Adrenaline is just a refurbished/rebuilt HPOP that's been modded.
I would buy a good set of guages, or an Edge CTS, then I would do the 6.0L transmission cooler mod if you are planning on towing a lot. Will help save the transmission. Then the intake and springs. Good luck in your decision. Oh yeah, got to have the Hellwig rear sway bar.
Stewart
Which AFE would you Recommend?
Stage 1? 2 or the Stage 2 with the Pro Guard intake? I'm guessing if I did it i would probably go for the Stage 2 or Stage 2 with Pro guard for maximum air intake.
Any Part # for the MBRP 4" you'd recommend?
Guessing we're talking about: Shipping Info
Thanks again Already thinking on when I can get working on the Ex... bout 3 weeks before Wife drops baby so wanting to get some stuff done before then
I would save your money on the AFE and look at the S&B if you are wanting a Cold Air Intake as the pricing is much better and you can't beat the quality.
If you can only do a couple mods I would focus on intake, exhaust, and a DP. Of course you can just keep going from there
Free Shipping on All Exhaust Systems and CAI kits as well.
