Developed a roar...
Old Jan 28, 2011 | 06:34 PM
Danger_Dave's Avatar
Danger_Dave
[QUOTE=merlynr]
There's one aspect of the driveshaft that I've read about, but haven't had to work with and it's the orientation of the u-joints(not sure of wording)when taken out and then put back in. They must be re-installed on same plane between the two drive shafts. This is more of a question than an answer.
Originally Posted by zoomer
If you don't line up the u-joints it will shake your teeth out. Mine would only go on one way. It is smooth up to 70 mph.
and if you drive it that way it can also cause "irreverseable damage"
