Inner fender
Old Jan 28, 2011 | 06:41 PM
TGenolcyC66's Avatar
TGenolcyC66
Inner fender
My inner fenders on the flat square area just below the hinges is bubbled and rotting away. Weird, it's a small area, on both sides. I've seen these advertised, are these easy to change, or should I try to repair it? Also, what causes this?
Old Jan 28, 2011 | 07:22 PM
drewbow's Avatar
drewbow
I have some caps that you can either weld in or bolt in if you're interested. they're probably about a foot long and and were made to solve this problem.
Old Jan 28, 2011 | 07:47 PM
BobbyFord's Avatar
BobbyFord
It is caused by the area being double-wall reinforced from the backside. Moisture and, in your case salt, is allowed to gather and cause corrosion. DC makes great replacement inner fenders (slightly thinner, but acceptable).
Old Jan 28, 2011 | 07:55 PM
TGenolcyC66
Shoot me an email jim@indy.net, would like to talk about the caps!
