Sponsored by: Real Truck
Help with fuel milage
Old Jan 16, 2011 | 10:20 PM
mikeslawn's Avatar
mikeslawn
Hello, Iam a new member but I have been a looker for years.
I bought a 1992 f350 4x4 with a 460 and a 3 speed auto and 4:10 gears
I would like to know if changing the gears in the front and rear end would be worth it to get better fuel economy?
Any other ideas??
Old Jan 17, 2011 | 02:45 PM
mikeslawn's Avatar
mikeslawn
Anyone have any ideas on how to squeeze alittle more miles per gallon??
Old Jan 17, 2011 | 03:17 PM
Wildfire532FB's Avatar
Wildfire532FB
what were you going to change them to? i would think 3.73s would be good for a 460 and a 3 speed. Are the 4.10s stock? Are you running big tires too?
Old Jan 19, 2011 | 07:31 AM
mikeslawn's Avatar
mikeslawn
yeah the 4:10s are stock. I run stock tires 235/85/16. pretty sure thats the size.
Is there anything I can do that does not cost as much as changing gears?
Will a cold air intake help? a throttle body spacer??
I love this truck and it runs and drives great. But the gas is killing me.
Could I put a AOD in it?
Old Jan 19, 2011 | 07:51 AM
edjunior's Avatar
edjunior
With that 460 and 3spd, I really doubt you're going to be able to squeeze more than a mile or two at best pg. I just don't see you being able to make up for it by adding all that other stuff. TBS has never been shown to have any significant improvement, cold air intake is iffy. The AOD may help if you do a lot of highway driving, not sure about daily/city. I don't think changing gears is going to help that much either, but could be your better bet. I would look at the cost of changing them, and the potential gain, and see if it is really worth it.
Good luck.
Old Jan 19, 2011 | 08:03 AM
mikeslawn's Avatar
mikeslawn
thanks.
Yeah that is what Iam trying to figure out. If it is worth chamging. Most of my driving with this truck is 45-55mph. 60MPH is to fast for truck. Engine is screaming at that point. Right now the truck is in 3 rd gear by 25mph. We use it to plow snow and haul a small dozer. With gas at 3.15 per gallon and going up it is getting crazy. But Iam sure everyone with a truck has the same complant.
Thanks for all the help. If anoyone has more ideas, please pass them on.
Old Jan 19, 2011 | 11:28 AM
redford's Avatar
redford
FTE Leadership Emeritus
Even if you did, is it worth it?
Say you change to a 3:55 gear set and your mileage goes up 2 MPG. You spend $800 to perform the change. If you were getting 10 MPG and now you're getting 12 MPG, your cost per mile went down about 5 cents. Your break even point is at 16000 miles. Will the truck be in service? Will you still own it?
These figures are estimates, but a 2 MPG gain and $800 are both very optimistic estimates. Most likely your payback will be somewhere around 35-40,000 miles.
Bigrig1979
Oct 4, 2012 09:45 PM
lonewolf777
1983 - 2012 Ranger & B-Series
Jan 28, 2011 09:11 PM
59flatbedford
Aug 20, 2010 10:11 AM
popatop500
Jul 5, 2009 10:53 PM
gsx
Apr 7, 2002 11:50 AM
