Question: What tool do you have, that you can't live without, that the average home mechanic probably does not have in his 155 piece Craftsman tool set?
The more important question: Why should I make this my next tool purchase?
For me it would be my new flexible head craftsman 1/2" and 3/8" ratchets. The head swivels to +/- 45 degrees (and more). This allow me to reach some bolts with a sturdy ratchet without having to breakout the u-joint adapters. Both can be bought together for around $50. It also allows me to make more of a rotation whereas with a standard ratchet I may only be able to turn 20 degrees. Fairly cheap, reliable, and saves time!
Also on my list of "must haves"
1. A really big breaker bar
2. One of those telescoping rods with a magnet on the end
3. A good shop light.
I would say a 9000# capacity 2 post lift. But maybe I'm the only one that feels they need one. *shrug*
A professional multimeter is essential.
I have a Wavetek MeterMan 34XR true RMS digital, and an older Simpson analog unit.
Both have their place.
Most useful 'go to' hand tool?
A pair of high leverage, angled head, diagonal cutting pliers. Klein, Knipex, Ideal or Channellock ONLY.... and in that order.
Whether pulling a cotter pin, grabbing a panel fastener, snipping a battery cable or just a zip tie. They are very handy and see constant use.
I have a LOT of tools. But other than your basic wrenches, ratchets and screwdrivers this is the one tool I always seem to have out on the tool caddy.
Next, a quality 1/2" drive 150'# capacity torque wrench.
A 4Lb. drilling hammer and a large brass drift would have to be up there too, but that depends on what you're doing.
assortment of hammers, regular, the sand filled type, rubber, brass and all differnt weights. 3 foot pry bar, A full air tool set including impact wrenches, air rachets, air chisel, grinder, sander, cutter, saw-zaw type air tool thingy and dont forget a good compressor, lights-type on stands, as well as the magnetic type and the ones that hook to stuff, long magnetic grabber thingy, "claw" grabber thingy-for if you drop a small bolt in a tight space
automotive specific: bearing packer/greaser, steering wheel puller, pully puller set, front end fork/puller set, hose cutter-for a cleaner cut on rad hoses and stuff, batterie charger/maintainer, TQ wrenches-ftlbs and inlbs
