Pros and Cons of 1.15 housing on the 38R?
Have you read this already? Little bit of info to start off with.
https://www.ford-trucks.com/forums/1...38r-surge.html
If you are going from a .84 to a 1.15 then it will be noiceable. Longer time to higher spool speed will be lengthened with a larger exhaust housing outlet no matter the size of the injectors, but the larger the injectors (more drive pressure and quicker) the shorter the time to higher spool speeds. If you are looking for lower egts and exhaust back pressure then it is a trade off.
on
I have Stage 2s and the 38r/1.15 combo. I drive in 60e most of the time. Spool up is a more noticably slower at the 50-55mph and lower speeds with my 3.73 gears, but comes on like gangbusters from 60 up. My tranny downshifts into 3rd below 60, under hard acceleration, spools up and away she goes! I just step on the accelerator and let the tranny and engine do its things. Most of the time, I just pass in OD without it downshifting at all. I have gotten so used to the way it runs that it all seems normal to me. Most people with a stock truck, with tuner and the basic mods, comment how hard it pulls and don't seem to notice the lag at all.
I haven't replaced the stock injectors (yet) so I can't answer if they would change how fast it spools, but keep in mind I'm at much higher elevation than most others, so the air I have to work with is less dense and makes lag worse.
Good point Brendan. I live at 5k and most of my driving is between 4500 and 7500 and altitude certainly makes a difference. I know I get a few pouinds more boost down in Phoenix and will have to pay more attention to the spooling characteristics next time I'm down there. I'll have to smoke out an on ramp or two with a WOT test.
1972fordhighboy
11-23-2014 08:26 AM
quality1construction
04-02-2014 07:51 AM
