Lubro Moly experience
Old Jan 15, 2011 | 09:15 PM
wreckinball's Avatar
wreckinball
moly anti friction (MoS2 experience.
On October 1st i used a can of the lubromoly from my napa. i was hoping to help with wear and tear. I had a very odd but extremely awesome result. On the package it said it can help prevent blowby. It definitely did. As you can see from my vid on the intake, it was nil blowby. I tried replacing the intake back to the original to see if that was the cause and it was the same amount, nil. I highly recommend that on your next oil change that you spend the few bucks on a can to stop or at least reduce the blowby you may be experiencing. It cost me 5.99 at the napa here in canada so it should be same or cheaper for you if you are in the states. Blow by is a major cause of oil consumption and if you remember when i said i smelled oil in my exhaust, well after i did the intake manifold gasket, it helped but it wasnt gone. When i did this and let it work for three months, my burnt smell in the exhaust is gone and nil blowby. I will permanently be adding this to my oil changes.
Old Jan 15, 2011 | 09:59 PM
rodneywar's Avatar
rodneywar
its a dollar cheaper here !! i added a pic so people could see what it looks like
Old Jan 15, 2011 | 10:10 PM
wreckinball
bwahaha i never saw the warning at the bottom...."may cause lung damage if swallowed??" WTF?
Old Jan 15, 2011 | 10:12 PM
rodneywar's Avatar
rodneywar
i thought it was odd too lol
Old Jan 15, 2011 | 10:19 PM
wreckinball
outstanding product though, cant recommend it enough.
Old Jan 15, 2011 | 10:23 PM
rodneywar's Avatar
rodneywar
you know they make diesel motor oil in 15w40!!
universal use for petrol and diesel engines with and without exhaust-gas turbocharging and with and without charge air cooling
- good cold-start behavior
- high lubricating film stability and high wear protection
- low evaporation losses
- high shear and aging stability
- good cleanliness and dispersant properties
- prevents black sludge
- mixable with all commercially available engine oils
- tested for catalytic converter compatibility
- neutralizes negative effects from fuels
Old Jan 15, 2011 | 10:54 PM
wreckinball
yeah how much is that? my 34 dollar oil changes are really makin me happy.
Old Jan 16, 2011 | 09:35 AM
rodneywar's Avatar
rodneywar
Liqui Moly High Tech Diesel 15W40, 5 Liter Bottle $27.95
Liqui Moly High Tech Diesel 15W40, Case of 4 $111.50
Old Jan 16, 2011 | 12:16 PM
wreckinball
still trying to get a canadian price tag on that.....we shall see but i would almost consider it if i could get it for 28 for a 5liter. Napa is closed today, or i would post it up. Probably be a bit more.
Old Jan 17, 2011 | 01:10 PM
wreckinball
HOLY CRAP, That oil is 63.50 for the 5L!!!!! Comeon Canada!!! WTF???
Old Jan 17, 2011 | 02:25 PM
Marianna2003's Avatar
Marianna2003
Hey Wreck, It's good to be King!!! You can name your own price!
Last edited by Marianna2003; Jan 25, 2011 at 02:51 PM. Reason: Add clarification to comment.
Old Jan 18, 2011 | 12:21 AM
wreckinball
lost me there?
Old Jan 18, 2011 | 04:49 PM
rodneywar's Avatar
rodneywar
DAMN IS ALL I CAN SAY!!!!
Old Jan 21, 2011 | 10:20 PM
GHeTTo JOe's Avatar
GHeTTo JOe
ok so i orded some of this from napa they never heard of it but the state distributor had 124 cans. did i read the measurents right i would need 2 cans for 12 quart oil cappacity?
Old Jan 21, 2011 | 10:22 PM
wreckinball
i just used one per oil change. if you used two i guess it would be similar but better results faster.
CISKOWSKI_21
6.4L Power Stroke Diesel
18
Apr 20, 2020 07:54 PM
Jethro Bo
16
May 15, 2017 03:26 PM
SidecarFlip
Transit Connect
24
Apr 17, 2016 08:50 PM
jgpowerstroke
Apr 2, 2015 08:48 PM
Lloydable
23
Dec 7, 2010 07:08 PM
