retard timming?
Old Dec 3, 2001 | 09:39 PM
oldblue18's Avatar
oldblue18
retard timming?
Old Jan 10, 2003 | 08:41 PM
forddytube's Avatar
forddytube
retard timming?
how could one retard the timming on 1991 f-150 v8 with least tools.thank you.
Old Jan 11, 2003 | 08:30 AM
RichB's Avatar
RichB
retard timming?
[updated:LAST EDITED ON 01-11-03 AT 09:41 AM (EST)]Run the engine until it is at operating temp. Loosen the bolt for the distributor clamp. Pull the spout jumper out and connect a timing light. You will probably need to clean the crankshaft vibration balancer to see the timing marks, I use a Scotchbrite pad myself. Fire up the truck and turn the distributor for the desired timing. Shut off the engine and tighten down the clamp. Recheck timing after the clamp is tight to verify nothing changed. Put the spout back in.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
