starting problem?
Old Jan 15, 2011 | 03:13 AM
cpetersen's Avatar
cpetersen
starting problem?
hey i just put a stereo system in my truck and now when i go to start it turns over really slow to start with but then fires right up wat would cause this?
Old Jan 15, 2011 | 08:50 AM
Royson12's Avatar
Royson12
Is it after you have been running your stereo for a while? Did you add any amplifiers to you stereo system?
Old Jan 15, 2011 | 02:20 PM
cpetersen's Avatar
cpetersen
ya i have one amp and if i have the stereo on it takes longer to start but when i turn it off it starts slow but then fires right up
Old Jan 15, 2011 | 02:25 PM
rupejosh's Avatar
rupejosh
sounds like the amp is constanly drawing power.is the remote wire functioning properly?
Old Jan 15, 2011 | 02:46 PM
cpetersen's Avatar
cpetersen
ya im thinkin iit is when i have the key turned the amp is on i turned the cd player off but the amp is still lit up when i have the cd player on when i try starting it has a really hard time and once i had to turn it over twice but when i have the cd player turned off it turns over really slow then starts right up it starts myabe half a second slower then when i didnt have the amp on it
Old Jan 15, 2011 | 03:19 PM
Royson12's Avatar
Royson12
I don't know what size amp you have, but it sounds like its robbing you of starting amps. If the amp is on while you are trying to start it? Depends a lot on the size of the amp also.
Old Jan 15, 2011 | 03:35 PM
cpetersen's Avatar
cpetersen
its only a 350 ill have to have my dad come out with me and watch the amp as i start it cuz when i turn the key to start it the cd player turns off so maybe the amp does to
Old Jan 15, 2011 | 03:36 PM
cpetersen's Avatar
cpetersen
o and hey royson12 did that url i sent you help you out at all?
Old Jan 15, 2011 | 03:44 PM
rupejosh's Avatar
rupejosh
if the cd player is off the amp should be as well did you run the remote wire(usually blue) from the cd player?
Old Jan 15, 2011 | 03:49 PM
cpetersen's Avatar
cpetersen
yup i did put that wire and i wired it into the line that it said to
Old Jan 16, 2011 | 10:16 AM
Royson12's Avatar
Royson12
I got that url, but i'm not sure that is what i'm lookin for. I think it is the single bracket that goes in the middle of the diff to the frame. Or is that what those brackets are?
Old Jan 16, 2011 | 11:01 AM
John D in CT's Avatar
John D in CT
Have you determined that the battery (or batteries) is/are fully charged, and in good condition?
Based on what you've told us, that's the first thing I'd do.
It's possible that the batteries were sketchy to begin with, and took a hit from powering your sound system for some time with the engine off.
Disconnect them and try to fully charge them, then test them with a proper battery analyzer like a Midtronics. That will tell you exactly how many CCA they have, and if they're good or bad.
Old Jan 16, 2011 | 01:10 PM
Royson12's Avatar
Royson12
Like that avatar Cpeterson! Where can i get one?
Old Jan 17, 2011 | 01:15 AM
cpetersen's Avatar
cpetersen
i cant remember if thats the one yoyu need i think it is and those batteries were both brand new 3 months ago
Old Jan 17, 2011 | 01:17 AM
cpetersen's Avatar
cpetersen
lol that buck was a b***** to get out 4 hours to go 1/4 mile lol im tryin to find the other big one iv shot its bigger than that one and its oregon lol
