Sponsored by: Auxito
please help code 0356
Old Jan 14, 2011 | 09:07 PM
staffbuoy's Avatar
staffbuoy
Please help me I have a2000 f150 5.4 got a code po356 ignition coil f primary/secondary circut malfunction.can someone tell me what that is.where to look.thanks
Old Jan 15, 2011 | 02:12 AM
Bluegrass 7's Avatar
Bluegrass 7
It is cylinder #6, second from tjhe front on the driver side.
Easy to get at.
Make sure the plug is on the coil first, then if so the primary/secondary winding may be 'open' as verified with a ohmmeter test. If yes replace the coil. Actual resistance means very little.
Rare, but if this does not find the issue, the harness is open or the computer driver for that cylinder could be faulty.
There is no more to it. The computer has reported the fault accuratly by code #.
Good luck.
Old Jan 15, 2011 | 07:29 AM
shorebird's Avatar
shorebird
Codes are available through Articles/Specs menu above;
Ford OBDII Diagnostic Trouble Codes - Overview .: Articles
You can swap coils between two plugs and see if the code moves to the new position.
Old Feb 7, 2012 | 07:33 AM
race4time's Avatar
race4time
You could save yourself a bunch of heartaches by testing before you go spending money on a bunch of parts. Get a small 12 VDC light bulb like a dash light bulb that has wire leads that can be pulled out and spread. Pull the connector off of the cylinder in question and plug the leads of the bulb into the two contacts on the plug. With the engine on, this "NOID" light should flash. One side of the connedtor should show continuous power which can be verified with just a test light. If you have 12 VDC on one side and your NOID light doesn't flash you either have a harness to PCM issue or a bad coil trigger in the PCM. If you test the wire from the cylinder back to the PCM plug and it tests open you have a broken wire somewhere. If it tests good and you don't show a short to ground then your coil driver in the PCM is bad. If your NOID light is in question, try it on another cylinder. You will see that it flashes there. If your NOID light shows good activity and no problems in wiring, THEN change your coil on.
Last edited by race4time; Feb 7, 2012 at 07:34 AM. Reason: P0356 is in primary circuit. It's not telling you the coil is bad. It's getting no drive.
Hhredneck
Southern Region
Mar 31, 2016 01:46 PM
APOLLO TROY
Sep 23, 2009 04:48 PM
2behad
New Member Introductions
Sep 8, 2009 02:02 PM
mc
Nov 2, 2004 12:20 AM
classicfordluvr
Aug 2, 2001 06:20 AM
