Engine Failsafe Mode
Old Jan 14, 2011 | 04:38 PM
sparee's Avatar
sparee
The '06 is startin to show her age. While driving, at normal speed, the engine went dead, no ps pb nothin and I was makin a turn. Info panel said Engine Failsafe Mode then came up low oil pressure. First time was low oil, did it again today 01/14/11 but oil is fine. Any help would be appreciated. Also my climate control is not working properly, blows hot then cold and fan doesn't adjustat all????
Old Jan 14, 2011 | 04:41 PM
Sako 75's Avatar
Sako 75
Get your codes read and post them up. I'm sure we will come up with something.
Old Jan 14, 2011 | 08:53 PM
Greg B's Avatar
Greg B
As to the climate control system, it sounds like the coolant level may be either low or there is an air pocket in the system. That would make for the temperature swing. The fan only having 1 speed is probably the blower motor resistor if it is manual control system. If it is the EATC system, you'll need to get the shop manual and diagnoze by the symptom. For the other problem, we need codes to steer you in the right direction.
Old Jan 14, 2011 | 09:33 PM
BGilley's Avatar
BGilley
Go on EBAY goto Ebay motors put in 04 thru 08 Ford factory service manual it has the answers!
Djeap1977
Jan 24, 2017 12:46 PM
Syncrowave
Apr 17, 2016 06:14 AM
americanbuckeye
Aug 19, 2015 06:38 AM
miyang
15
Jun 22, 2015 08:45 AM
442w30
2004 - 2008 F150
Aug 5, 2005 10:19 PM
