As most of you know the 300 straight 6 comes stock with a single barrel carb. would it be possible to put a 2 or 4 on? if so, is there anything special that i need to do?
You will need to swap out your intake manifold. There is a few opitions you can go with. Offy DP with a edlerbrock 1403 500 cfm or you can go with a clifford setup. Go to 300 inline 6 forum on here. There are tons of write up's about what you wanna do.
BTW i just did the Offy DP intake, hedman header, Edlerbrock 1403 and dual exhaust with 40 series flowmasters. Just that alone woke her up. All my friends that have v8 are shocked when I raise the hood. In a few weeks going to install comp cam260 and P&P my head. So far Im getting ok MPG. 17 city/21 hiway
