pyrometer question
Jan 13, 2011 | 11:22 AM
pyrometer question
can i use a banks pyrometer that came in the cummins package in the truck? i already have a trans temp and and a boost just need the pyro and would like to use this banks one if possible. thanks guys
Jan 13, 2011 | 11:40 AM
You should be able to. I would look at getting a new probe though...
Jan 13, 2011 | 11:43 AM
A pyro is a pyro, as long as you have the gauge head, lead wire and the probe you'll be fine.
Jan 13, 2011 | 11:44 AM
Quote:
Originally Posted by
superduty4x4
x2.
id take a lighter or something and test the probe before you install
Jan 13, 2011 | 11:57 AM
ccarrier
x2.
Propane torch, a lighter isn't gonna put out much heat.
Jan 13, 2011 | 12:01 PM
superduty4x4
true, i used a lighter on mine just too see if it would move
Jan 13, 2011 | 12:06 PM
its brand new never been used or installed. it also came with the probe(new), wiring, gauge head and a 2 gauge mount.
Jan 13, 2011 | 12:12 PM
Well what are you waitin for? Install it!!
Jan 13, 2011 | 01:22 PM
The key is to make sure the thermocouple used (probe) is the proper "Type" for use with the gauge. Most (not all) use a Type K and tehy usually interchange between sources without any issues.
