2wd-4wd
Old Jan 13, 2011 | 10:55 AM
jnl72's Avatar
jnl72
2wd-4wd
I have a 1979 f150 supercab with new paint,and in good shape. My 1979 f350 4wd is in bad shape body wise. It has the L&L 460 conversion with a good running gear under it, or should I look for a 4wd supercab frame?
Old Jan 13, 2011 | 11:03 AM
Edgethis's Avatar
Edgethis
What are you asking here? If it would work to swap bodies?
Old Jan 13, 2011 | 11:36 AM
jnl72's Avatar
jnl72
Just wondering if I should swap the 2 trucks or look for a new frame. I like the setup that the f350 has. The supercab is a long box as is the f350 is a regular cab long box.
Old Jan 13, 2011 | 12:16 PM
Edgethis's Avatar
Edgethis
There's a thread somewhere on here that showed what was swap-able. body wise. If the wheel bases and frame widths are the same I'd say go for it.
