i need help !!
Old Jan 12, 2011 | 10:08 PM
spike200163's Avatar
spike200163
Red face i need help !!
i have a 1989 f-150 5.8 here's the problem my idle is really high i have replaced the tsp and the iac but when i frist replaced the tsp the idle went to normal but in a few mins it got high again . so any idea whats going on ????
Old Jan 13, 2011 | 12:20 AM
Domestic_Nuwbee's Avatar
Domestic_Nuwbee
how high?! check the voltage to TPS and check for vaccum leaks also....trace all lines. I have the same problem, however I got the code which pointed me in the direction of the TPS.
Old Jan 13, 2011 | 12:31 AM
Domestic_Nuwbee
check the signal voltage to the TPS as well with voltage meter
idle - 0.5-1.0
open throttle - 4.0-5.0
Courtesy of RLA, he corrected me on the open throttle reading.
good luck,
Engine is off, just turn key.
Old Jan 13, 2011 | 03:04 AM
xxshine's Avatar
xxshine
One thing i found to cause a high idle is the water temp. sender that goes to the computer. Didn't want to spend $$ on that stupid thing, so i crossed up the wires. No more high idle.
Old Jan 13, 2011 | 02:42 PM
spike200163
still need help ?
ok i replaced the tsp and i replaced the iac so now im looking for a leak some where so i'm also thinking maybe the map sensor too .
Old Jan 13, 2011 | 02:44 PM
spike200163
its not the water temp sensor from a cold start
pjwoolw
Ford Truck Parts for Sale
Apr 22, 2013 09:38 AM
dmack91
Nov 19, 2012 01:54 PM
dev-el paso
Bronco II
Dec 22, 2003 06:27 PM
drittler
1978 - 1996 Big Bronco
Apr 16, 2003 08:11 AM
sdgrant150
Jul 10, 2001 06:47 PM
