e40d tranny problems!!! please help
Old Jan 12, 2011 | 08:43 PM
fordguy1988's Avatar
fordguy1988
i was plowing an put it in reverse backed up like 20 feet stopped and went to back up some more an it was acting like it was in nutural... no bang no noise or nothing.. not leaking fluid at all... so no reverse or 2nd gear... anything i could do before buying an rebuild kit??
Old Jan 12, 2011 | 08:48 PM
darthice's Avatar
darthice
sounds like a stuck valve drop the pan and check the valve body
Old Jan 12, 2011 | 08:53 PM
fordguy1988
ok thanks... another thing.. i let sit allday when i got back 12 hours later i started it up put it in drive moved it forward,then put it in reverse it went in moved an inch then slipped did it a couple times then when fluid get hot it does nothing!!!
Old Jan 12, 2011 | 09:06 PM
96f350az's Avatar
96f350az
planetary gear um "half" broken? lol
