Sponsored by: Auxito
Need Some Help...
Old Jan 12, 2011 | 07:32 PM
seadooxp's Avatar
seadooxp
Need Some Help...
I have a 2000 F-150 4X4 with 80K. Every once and a while when I am backing up I hear a clunk or bang that feels like something just came unstuck. I have checked the brakes and its not them, I have 4 wheel disc anyway. But what happens that weird's me out is it feels like the truck doesn't want to move back anymore after this happens until I (in my opinion) give it more gas then I think I should to get it going again. Then it may happen again it may not for two days. I replaced one of my U-Joints and checked the other so I have ruled them out, what else could this be?
Old Jan 12, 2011 | 10:20 PM
Dave G.'s Avatar
Dave G.
Still at it I see ? With disc brakes in the rear, it's more than likely the e-brake shoes causing the problem. The hardware tends to corrode away, and if the main lower springs goes, the shoes will drag hard against the interior drum of the disc brake rotor. Can't really check them without pulling the rotor. First try the e-brakes. Do they seem to release ? They are easy to replace, once you get the rotor off.
Sort of back to your original issue, and a variation of my first thing to check I guess.
Dave
Old Jan 13, 2011 | 06:49 AM
torkum's Avatar
torkum
I agree with Dave and don't overlook the front wheel hubs and brakes too. Get it off the ground and check all 4 wheel components.
Old Jan 13, 2011 | 03:22 PM
seadooxp's Avatar
seadooxp
UPDATE
I had my wife back up the vehicle and noticed that the right rear wheel locked up when I heard the noise....Called Ford dealer they said pull the brakes apart and look at it.
Old Jan 13, 2011 | 04:32 PM
Dave G.'s Avatar
Dave G.
Almost guaranteed to be the e-brake shoes. Check ahead of time for shoes and hardware for both rear wheels.
Dave
Old Jan 14, 2011 | 04:18 PM
seadooxp's Avatar
seadooxp
YES! all fixed, the hardware failed inside there. Cost me 24 for the parking brake shoes for both wheels and 24 for the hardware for both wheels. I am very happy, thanks for all the help!
Old Jan 14, 2011 | 05:48 PM
Dave G.'s Avatar
Dave G.
It's a pretty common problem because rear pads/calipers can be serviced without necessarily removing the rotor. Most trucks probably get a couple of brake lining changes before this problem crops up.
Dave
thomas910
1983 - 2012 Ranger & B-Series
Mar 18, 2013 09:45 PM
frankiethethumper
Jan 14, 2013 08:16 PM
jasontrucks76
Dec 2, 2010 08:34 AM
reefman
Nov 14, 2007 08:43 PM
