detroit Locker
Old Jan 12, 2011 | 01:54 PM
OneTon4Fun's Avatar
OneTon4Fun
detroit Locker
I appoligise for posting here but I got no answer in the chassis forum.
Does a detroit locker for a dana 80 (rear axal on f350 dually) slip any?
Or does it simply lock the differential without any slip for turning.
Old Jan 12, 2011 | 02:09 PM
AGE mechanic's Avatar
AGE mechanic
You might feel or hear some clicking when you turn, but straight, it is locked up tight. Take a look at the Truetrac. Might be a better option on a daily driver.
Old Jan 12, 2011 | 02:11 PM
Misky6.0's Avatar
Misky6.0
I've got detroit lockers in my Jeep (both front and rear).
It shouldn't matter what vehicle, they all work the same:
Under power the lockers "lock" the left and right wheels together,
thus they rotate @ the same speed - NO slip.
In 4x4 under power it makes turning a challenge because the
front wheels like going straight.
On pavement, the rear inside tire chirps in the parking lot because
the radius is less than the outside tire (when on the gas).
When coasting, you'll hear the click indicating they are NOT locked
in a turn.
Old Jan 12, 2011 | 02:33 PM
OneTon4Fun's Avatar
OneTon4Fun
Thanks for the fedback. I plan to put the locker on the rear axal and leave the front as is whithout any limited slip or locker unit.
Old Jan 12, 2011 | 02:34 PM
TexasA&M's Avatar
TexasA&M
The longer the wheelbase, the less you notice the locker (when installed in the rear). I've got a long bed '86 Chevy and hardly notice the locker in the rear when daily driving on the street. You do need to be more careful when the roads are slick because it is more likely to lock up during a turn, but a light left foot fixes any issues there.
I have a TruTrac in the front end of that same truck and really like how it operates. It works great for the front end because it allows you to steer just like you have an open diff, but allows very little wheel spin. I don't know if I'd put one in the rear of a heavy truck though because I don't think they are quite as heavy duty as a true Detroit locker. I could be wrong about that last statement though.
Old Jan 12, 2011 | 02:41 PM
Misky6.0's Avatar
Misky6.0
If you do serious off-road, I would suggest air activated lockers.
The added flexibilty is good, but I didn't want to spend the $$$.
I'm pleased with my lockers frt and rear, I've pulled a little
but heavy utility trailer up our snow covered driveway
(12% grade) and had all 4 wheels spinning at one point.
Old Jan 12, 2011 | 02:47 PM
AGE mechanic
If you are mostly on the street, I would suggest the TruTrac. The reason being, it will help you keep traction on wet or icey streets. The locker will act more like a spool in those conditions.
Old Jan 12, 2011 | 02:56 PM
Misky6.0's Avatar
Misky6.0
I agree. I've had too many rental 4x4 vehicles with open front/rear
and they couldn't make it up my driveway in CO. So, before
we moved our Jeep to CO, we "upgraded" it now I don't rent
Old Jan 13, 2011 | 07:19 AM
OneTon4Fun's Avatar
OneTon4Fun
What is the cost of the locker? Randy's Ring and Pinion lists the locker for $704. Is this a good price?
Old Jan 13, 2011 | 02:41 PM
Diesel Smoker's Avatar
Diesel Smoker
Check out 4wheelparts they have some good sales.
Old Jan 13, 2011 | 04:41 PM
AGE mechanic
Not really, you can find it cheaper than that. Maybe low to mid sixes is what you should pay.
Old Jan 13, 2011 | 06:39 PM
az4x4bronc's Avatar
az4x4bronc
I have run a detroit in my Bronco rear end for many years and I hardly notice it on the street. Off road it locks up real good and it is tough. I think the longer wheel base and the automatic transmission helps, in the jeeps it is much more noticable. I have a ARB air locker in the front.
Try looking on ebay for a better price.
V10E350
Mar 12, 2015 06:22 PM
defiantoutlaw
21
Jul 8, 2014 01:28 PM
J ballan
18
Dec 3, 2012 08:59 PM
abriel68
Feb 2, 2010 10:16 AM
doop
Dec 9, 1999 07:42 PM
