check engine light
Old Jan 14, 2011 | 11:09 AM
JamesHajek's Avatar
JamesHajek
Do you have your exhaust back pressure valve unplugged? That would be my guess for that code. The 1211 means your either you have a bad ICP sensor or your HPOP was losing pressure pretty fast during a WOT run. I would guess the boost malfunction was from your split boost line? The low voltage one means you should start checking your battery connections and grounds. Maybe clean your battery terminals.
voltfox
Sep 21, 2015 04:46 PM
Aerostar65
Aerostar
Dec 30, 2009 10:24 AM
Moore558
1983 - 2012 Ranger & B-Series
20
May 12, 2008 11:45 PM
Flareside351
15
Dec 12, 2004 03:04 PM
Dett
36
Nov 26, 2004 11:56 PM
