MPG dropped dramtically
Old Jan 11, 2011 | 11:10 PM
Domestic_Nuwbee's Avatar
Domestic_Nuwbee
Hey guys,
Any of you lose mpgs after seafoaming?!?! I seafoamed over the weekend with great results. Truck runs, sounds, and feels better but noticed she's drinking a lot faster! I was getting 16mpg and proabably way below that now. I have actually never payed attention to what mileage i get in total off front and rear tanks. But lets put it this way.... i went through half a tank in 2 days doing my daily drive to work and back home....and then the corner store 5 blocks from my house. Half a tank can last me up to 3-4 days depending how heavy my foot decides to be that day. I also have a faulty TPS, which was prior to seafoam. Mind you, after seafoam my warm idle is high now. Is this decrease from the seafoaming or tps!?
Old Jan 12, 2011 | 01:42 AM
LCAM-01XA's Avatar
LCAM-01XA
Replace your TPS, then worry about what the seafoam may or may not have done. The PCM uses the TPS to determine how much fuel to deliver in the cylinders, when TPS ain't right the PCM may go into keep-alive mode and just pour fuel in to make sure no matter what you won't stall... Which is probably what's going on right now.
Old Jan 12, 2011 | 07:46 AM
rla2005's Avatar
rla2005
Add in your right foot is "feeling" that new power as well. Trust me, it happens!
Old Jan 12, 2011 | 08:49 AM
deeznuts822's Avatar
deeznuts822
Probably is the gas. I've been getting crappy mileage Lately But a different fill up and it was back to normal.
Old Jan 12, 2011 | 09:39 AM
timbersteel's Avatar
timbersteel
What everyone said.
Then you could have the dreaded fuel pump FDM going bad, as in my case, when I was driving on the rear tank and then went to somewhere later that day and next it was pumping into the front tank.
Old Jan 12, 2011 | 10:40 AM
oldfordisbetter's Avatar
oldfordisbetter
could be winter gas....
Old Jan 12, 2011 | 10:53 AM
Domestic_Nuwbee
Well...I've taken my heavy foot into account but can't move anywhere too fast with traffic so I'm positive my driving pattern hasn't changed. I'm leaning towards the TPS, as my idle is high now (1200rpm) and fuel is just getting dumped in at idle. I picked up a new TPS and will be replacing it soon. I use the same gas as always, Mohawk 91 octane. Will let you guys know what happends. Thanks guys.
Old Jan 12, 2011 | 11:05 AM
motorhead81's Avatar
motorhead81
I think the ethenol content in gas veryies from time to time
Old Jan 12, 2011 | 11:41 AM
Bob Gervais's Avatar
Bob Gervais
Winter blend gasoline, depending on where you live, is different. Most times it results in lower fuel economy.
Also, the high idle after Seafoaming, I'd check to make sure you don't have a vacuum leak. This would account for the high idle, and lower fuel mileage.
Old Jan 12, 2011 | 12:55 PM
Domestic_Nuwbee
No vaccum leaks from what I can see, I traced all the lines possible. However, i got a code thrown at me about my canister purge (coffee can) that wouldnt effect it do you think?
Old Jan 12, 2011 | 01:03 PM
Bob Gervais
A purge code would most likely be for the charcoal canister purge valve, different than the coffee can. I get that code from time to time as well, but haven't had a chance to dig into it yet.
Maybe try spraying some carb cleaner around the line you removed to put the Seafoam in, and just double check for leaks?
Old Jan 12, 2011 | 04:12 PM
Domestic_Nuwbee
Oh ok, what/where is the canster purge valve?
I used the brake booster line for the seafoam. I double checked all my lines and cleaned the vaccum tree as well out of interest.
Old Jan 12, 2011 | 04:29 PM
Bob Gervais
Location depends which engine you have. On my 302, it's in the front, below the throttle body. Mine isn't attached to a bracket or held by anything (not sure if it's supposed to be). You'll see two vacuum lines, and an electrical connector on it. One end goes to the manifold, and the other one goes to the charcoal canister.
Speaking of the coffee can though, check that as well. Mine looked great on the topside, and the bottomside was rotted through, causing a vacuum leak.
Old Jan 12, 2011 | 04:49 PM
motorhead81
that code is emissions related won't raise idle
Old Jan 12, 2011 | 05:17 PM
Domestic_Nuwbee
Which code?! the TPS one or Canister Purge?
