Bronco II Ford Bronco II
Pinging
Old Mar 6, 2003 | 09:47 PM
loud88GT's Avatar
loud88GT
Pinging
Just wondering if anybody has had a problem similar to this and what they did to fix it... After my '89 B2 warms up it will ping under acceleration. I checked the timing, and it was set to the factory spec. Since it only occurs when the engine is warmed up I was thinking maybe the O2 sensors are bad. I guess I'm not sure where to start, besides checking the timing. Any help would be greatly appreciated.
Old Mar 6, 2003 | 11:43 PM
BKSasquatch's Avatar
BKSasquatch
Pinging
My guess would be spark plugs either worn, clogged with combustion chamber crud, or the wrong heat range. Secondly, I would look at cap/rotor/wires. Does it seem to run hot when after it warms up? That would cause high head temperatures and cause pinging too... Good luck Brian
spalmer
4 Cylinder Engines
Dec 13, 2009 07:27 PM
XLT2.5L
1983 - 2012 Ranger & B-Series
Oct 3, 2009 10:06 PM
KennethKvittum
1997 - 2003 F150
Jul 9, 2006 02:20 PM
kbarrett
Nov 6, 2002 06:43 AM
dc10sean
Mar 28, 2001 05:29 PM
