2003 F250 Problems
Old Jan 11, 2011 | 06:53 PM
tamiwilson's Avatar
tamiwilson
Thanks, I will drop the tank this weekend.
Old Jan 11, 2011 | 06:56 PM
tamiwilson's Avatar
tamiwilson
Originally Posted by bismic
I raised the bed. I used a floor jack and a cut-off piece of 4x4 to lift it (after unbolting). I then used 4x4 or 2x4 pieces (can't recall which) to wedge under the bed to keep it raised and prevent the possibility of it falling on me. I took out all but the back two bolts (torx type, but I forget the size). I loosened the back two enough to allow it to be lifted. Leaving these two still loosely screwed in helps to keep the bed stable.
https://www.ford-trucks.com/forums/2...-the-tank.html
Thanks for the info, I will look into both options. Very helpful information. This might be easier than dropping the tank.
Old Jan 11, 2011 | 07:55 PM
tamiwilson's Avatar
tamiwilson
Harpooning the tank
Powerstroke Fuel Tank Modification
(thanks Bill!)
I read the about the process. Bill provides some nice photos of this process and lifting the bed does seem easier. But I have been able to successfully fill my tank previously without the clicking off problem and get within four gallons of a full tank, the problem started recently so is harpooning the tank nessesary?
Old Jan 11, 2011 | 08:05 PM
bismic's Avatar
bismic
Harpooning advantages:
- fills the last 3-4 gallons a TON faster
- since the last few gallons are filled faster, you are more likely to fill it completely full each time so hand calculated mileage is accurate each time
- gives you more miles you can go before re-fueling
- allows you to fill up QUICKLY at the 18 wheeler fuel pumps
Harpoonong isn't really necessary but it is a great convenience.
5Rangers
Jul 25, 2011 09:42 PM
K8's Ford
13
Oct 19, 2010 05:39 PM
FruitPunch
Jan 4, 2010 01:46 AM
UBDog
22
Jan 10, 2007 10:37 AM
BurnOil
Jan 4, 2005 08:12 AM
