Power steering Box
Old Jan 11, 2011 | 01:34 PM
Coolarctic's Avatar
Coolarctic
Power steering Box
Hay Fellows,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Looks like the cold weather up her has finally blown the seal in the top of my power steering box, I have a spare box from an f150, Model # D9AC-AA. Will it work in my 89, F250, 7.3l Diesel?<o></o>
I Can't read the # of the box on my truck as they have rusted off.
Old Jan 11, 2011 | 02:17 PM
LCAM-01XA's Avatar
LCAM-01XA
Box is the same from F15o to F-Superduty, also E-series vans. You should be good to go, just as long as the F150 it came from is not a '97 or newer, or '79 or older.
snaponprofile's Avatar
snaponprofile
Mine just blew a seal also and I'm currently trying to get the pit arm off. Its in this thread, you gonna repace the seals or the entire box??
Old Jan 11, 2011 | 02:18 PM
LCAM-01XA's Avatar
LCAM-01XA
He's swapping boxes, that's what I'd do too if I have a good box as it sure beats messing with them seals.
Old Jan 11, 2011 | 04:30 PM
vfelix702's Avatar
vfelix702
box swap is easier when your in a jam you can replace the seals when its on a bench so you can see what you are working on then put it on the shelf when needed youll have a perfectly good one
Old Jan 12, 2011 | 09:17 PM
Coolarctic's Avatar
Coolarctic
Hay Guys,
Thanks for the info, I'm going to swap out the steering boxes, looks like a pain in the *** to swap seals. The old one is off and i just changed over the pitman arms as the 250 is heaver duty, another hour or so and i'll be back on the road. Thanks for the help and i'll let you know how it turns out. Great to have a heated shop, -40 here today with the wind.
Cheers
Truckandute
Aug 28, 2014 01:42 PM
bkuuz1
May 2, 2014 09:47 AM
Scornwell
6.4L Power Stroke Diesel
Dec 13, 2013 05:26 PM
pdhj1990
EcoBoost (all engine sizes)
Dec 1, 2012 12:16 AM
smkf100
Oct 12, 2011 04:29 PM
