Hello everyone, I,m working on my fathers work truck. 1999 F350 superduty dump truck with the 5.4 triton and hes having problems with it and i managed to pull up some codes. Whats strange is its not firing on the front 4 cylinders and it happened all at once. Any help would be greatful and possably a walkthough.
I found the small nipple broken off the DPFE, i hope that was the problem. I,m jb welding it back together and hoping it holds, Also i found the wire was off on bank 2. I,ll post results in a little bit.
Thank you for the help sir. Everything went great and don't have the misfires or a check engine light anymore. Its running smooth as can be. I will keep this forum in mind. Again, Thank You.
