Sponsored by: Auxito
Squeaky front end
Old Jan 10, 2011 | 10:21 PM
seleberry's Avatar
seleberry
Squeaky front end
All of a sudden, LOUD squeak from front end when it bounces or turns. Sounds like it is coming from the middle of the truck (not left or right). Drives straight, brakes fine, no tranny issues? Something needs to be lubed...not sure what. Any ideas?
Old Jan 10, 2011 | 10:59 PM
swillett's Avatar
swillett
sounds like your front end is dry.
for some brilliant reason i was only able to find 1 grease nipple in my front end when it was wailing but.....
all of your ball joints are encased in rubber dust boots.
get a grease gun with a needle on the tip and pump all of your dust boots full until grease bulges out.
noise should shut up within an hour or so of driving.
i used a sharp pick to peirce the boots before i shoved the needle in
Old Jan 11, 2011 | 05:39 AM
n5926g's Avatar
n5926g
Unfortunately thats about the only way to do it.These ball joints were "permanently lubricated" meaning,when they go dry...they are indeed dry.The hole in the boot,and grease is usually a temporary fix,perhaps a year.After that its time to have the Ball joints replaced with actual grease fittings on them.
Old Jan 11, 2011 | 08:51 AM
seleberry's Avatar
seleberry
Thanks. Whaddup with the non-zerked fittings? I tried some of this last night...long process
we287gn
32
Dec 15, 2014 06:44 PM
Roger T. Pipe
Apr 3, 2014 08:32 AM
tomrflorida
Mar 18, 2014 12:57 AM
73 ford guy
Jan 17, 2014 06:27 PM
