I just purchased the WW. I'm reading that some guys don't like it and some are saying it is bad for your turbo. I do pull a 10,000 pound horse trailer and I'm looking for a little pick me up. I have a 4" straight pipe and an open air cleaner. What do you guys think of the wicked wheel. Oh yeah, I have a 97 F350.
IIRC, 94.5-97 PSD's came with a "WW" style wheel installed from the factory. This is an upgrade [EDIT: DOWNGRADE, SEE BELOW POSTS] for 99+ SD's to help with turbo surge. Unless yours is damaged, there would be no performance upgrade from install the wheel. Someone can correct me if I'm terribly mistaken.
Robb
Reason: See Below Posts
IIRC, 94.5-97 PSD's came with a "WW" style wheel installed from the factory. This is an upgrade for 99+ SD's to help with turbo surge. Unless yours is damaged, there would be no performance upgrade to reason to install the wheel. Someone can correct me if I'm terribly mistaken.
Robb
It's not an "upgrade" for the SD wheel.
The SD Wheel is far more aggressive than our turbo wheel.
However, you are not incorrect on the other info.
Surge is from lack of air to the wheel.
It's not like surge in a gas engine. Most people mistake turbo surge for bucking or other things.
To fix the SD surge issue, you should put a bigger intake on the turbo. Viola, more power, instead of a band-aid to cover up the problem.
Thanks for the information, I will return the wheel. Is there something I can do to the turbo without buying a whole new turbo. I've seen a new cover you can buy with a bigger port. Does this help? Thanks for your guys help
Sean
Nobody makes a ported shroud housing for the OBS turbo that I'm aware of. There may have been something at one time, but not anymore.
What are you trying to accomplish? You can install a 1.0 exhaust housing to get a little quicker spool up. Other than that there aren't many options for the turbos for these trucks.
What are your goals for the truck? What do you use it for? We might be able to give you a little direction rather than having you buy stuff and then ask if its a good buy...
I pull a 4 horse trailer with living quarters, it weighs 10,000 without horses. I'm just trying to make it pull a bit better. I have a 4" straight pipe with an open air cleaner. I have shimmed the fuel regulator. I was hoping to get my turbo to spool a little faster. Any thoughts would be great. Thanks
Talk to Jim at Rosewood diesel for an upgrade on your stock injectors. Not near as expensive as you may think. First though, put some gauges in, pyro, boost, tranny temp if auto. Add a good custom chip and you're good to go. My trailer pictured weighs +-16k loaded and I set the cruise at 75 and go, kick off in hills to keep exh. temps down. Mods are in my sig. Look into an intercooler also means you pull a lot of weight. DIY an intercooler for about 400 bucks, give or take. If you do this, you will need a bigger hpop to run the injectors fully, also not near as expensive as you may think. Talk to joey@terminatorengineering for help there. Your stock turbo is fine with upgrades like these
Depending on how much you are looking to spend... A good start for that would be a custom tuned chip with a tow program.
You have the exhaust and intake which are good. Next would be gauges to keep an eye on temps. Most important gauge is a Pyrometer or Exhaust gas temps gauge.
So gauges, then custom tuned chip. See what that does for you. If your still looking for more, you will need to build your injectors which can start to get spendy.
