heater problem 96 f150
Old Jan 9, 2011 | 08:30 PM
jhharmon's Avatar
jhharmon
I have a 96 f150, and the heat does not blow out hot. i know the heater core is good, both hoses are hot. i think that the blend door between the heater core and evaporator core may be stuck. it looks like it might be cable driven, but not sure. what does it take to get to where i can look at this door? any other suggestions?
Old Jan 9, 2011 | 09:18 PM
aguitarestv's Avatar
aguitarestv
it might be vacuum powered, check out the vacuum lines that run to it on the fire wall (if it is indeed vacuum powered)
Old Jan 9, 2011 | 09:38 PM
minnesotafisherman's Avatar
minnesotafisherman
Does the engine temp. fluctuate while driving? You may need a new thermostat.
Old Jan 9, 2011 | 10:48 PM
Slowroll90's Avatar
Slowroll90
but the heater core hoses are hot?
Old Jan 10, 2011 | 05:44 PM
jhharmon's Avatar
jhharmon
temp does not fluctuate at all, and both hoses are hot, i have checked all the vacuum lines i can see and they are good.
Old Jan 10, 2011 | 05:47 PM
jhharmon's Avatar
jhharmon
anyone know where i can find an exploded view of the heater/air box under the dash.
Old Jan 11, 2011 | 11:37 PM
Slowroll90's Avatar
Slowroll90
i may be in the same rut interested in more info
krazykrenz
Dec 30, 2014 05:48 AM
HMAN1055
13
Dec 15, 2014 11:44 AM
starduster31
1997 - 2003 F150
Dec 6, 2014 08:57 AM
jagger blaze
1997 - 2003 F150
Nov 18, 2014 09:40 PM
brandon olson
1997 - 2003 F150
13
Dec 30, 2013 08:02 AM
