White Smoke Until Warm
Old Jan 9, 2011 | 07:32 PM
Mitch1407's Avatar
Mitch1407
Hey fellas,
Got another issue. Other posted issues were resolved. The skip was from the Oil pressure regulator. However, I also unknowingly had a blown turbo. Replaced it with the factory Garrett brand and now I am having some white smoke billowing out the stack when its cold. The truck actually feels like its missing if you drive it before its in the normal op range. I believe it is getting too much fuel to cause this, or I have a faulty glow plug relay or bad glow plugs. I'm starting to become irritated . I am praying its not a blown headgasket. One of the reasons that I believe that it is a glow plug related problem is because the smoke goes away after warming up and the exhaust does not smell like anti-freeze. I will be checking the levels just to be sure.
Thanks for any input,
Mitch
Old Jan 9, 2011 | 08:01 PM
F350-6's Avatar
F350-6
Sounds glow plug related to me. Read the hard start sticky at the top of the page for instructions on how to test your GPR and glow plugs with a meter.
Old Jan 9, 2011 | 08:03 PM
riverrat41's Avatar
riverrat41
Some white smoke is not really alarming.Do you have a GPR led so you can tell when it is on?Have you checked the output of the GPR?What about a CEL?
Old Jan 9, 2011 | 08:06 PM
Mitch1407's Avatar
Mitch1407
I do not have an LED hooked up. When I get access to a meter then I will check this. Thanks for the input.
Old Jan 9, 2011 | 08:08 PM
bcaughhorn's Avatar
bcaughhorn
im no expert but sounds like glow plugs to me
Old Jan 9, 2011 | 10:21 PM
SLUF681's Avatar
SLUF681
Do the GPR LED. 10$ at radio shack and 30 minutes. Love mine.
Old Jan 9, 2011 | 10:44 PM
robs01f250's Avatar
robs01f250
yep so the led so you can for sure tell if your GPR is good or not
Old Jan 9, 2011 | 10:51 PM
white Buffalo's Avatar
white Buffalo
X2..............
Old Jan 10, 2011 | 08:37 AM
Mitch1407's Avatar
Mitch1407
I will definitely be getting the LED asap. Also I am trying to sell my DP-tuner comes with everything except instructions, with tunes: stock,80 econ,140 agress, 140 supersmoke, lope. Buyer will have to get the chip programmed for their PCM.
If anyone can post a link where I could repost this add it in the appropriate area it would be great!
Thanks,
Mitch
Old Jan 10, 2011 | 08:40 AM
bcaughhorn's Avatar
bcaughhorn
Just make a thread in the same forum. If I had any extra I would buy it but santa killed me
jgrohs54
22
Jul 19, 2017 09:36 AM
Papers
Mar 21, 2017 08:47 PM
Dezl Newbie
28
Jan 5, 2017 06:59 PM
Alec Blanchard
19
Apr 10, 2016 11:24 AM
linus72
Apr 16, 2012 07:40 AM
