Ok my truck runs great .. never dies etc .. but when I lightly push the gas pedal the truck seems to start running rough and at a lower idle. Also when i'm driving, the truck shifts in to any other gear and the power drops for a couple seconds then the power comes right back.
It could be a simple fix. Check wires, dis cap, rotor, and plugs. I had wires look new and have holes burnt through the underside thus causing spark-jump. This is very noticable when hard on acceleration. Hope this helps. Jake.
