needed: proper engine
Old Jan 9, 2011 | 04:23 PM
gene s's Avatar
gene s
Hello,
WE have a 1977 1 ton duallie truck used to deliver water. When loaded with its 725 gallon load it is right at its max limit of 10,000 gvw. The 360 2bbl. engine is about shot. This truck delivers water to those of us who are out of water.
I need some information as to the replacement engines available for this type of truck. I presume the standard blocks available from the old days of 360- to 427 would fit in this old truck. I was told yesterday that the newer series of Ford truck engines will also fit this old truck if the newer bell housing is used to fit our old standard 4 speed transmission.
We are in a fiscally desperate situation and must locate an engine that will fit into this old rig because our water needs are acute. What engine do you suggest would fit best and not require some work with regard to modifcations to starter, exhaust manifolds etc? I know practically any Ford truck engine would be more powerful than our present one. We don't need a hot rod, we need relaible power.
Thank you in advance for any help you can give us in this matter.
Gene S.
Old Jan 9, 2011 | 04:31 PM
impalaslayer's Avatar
impalaslayer
when a 360 is in good condition it should have plenty of power for what you need. id look for a replacement 360 or 390 and they would be your most direct replacement.
Old Jan 9, 2011 | 04:37 PM
jtm1989's Avatar
jtm1989
352, 360, or 390. Have you consider rings, bearings & gaskets. A 360 will run along time burning oil, just keep it full and clean the plugs when it gets rough.
Old Jan 9, 2011 | 05:03 PM
bamaf150's Avatar
bamaf150
Well if it really is a 1977 model it shouldnt have a 360, 1976 was the last year for the 360. Are you sure its a 360? If you dont mind me asking, where are you located?
Old Jan 9, 2011 | 05:06 PM
bamaf150's Avatar
bamaf150
In any case, your simplest and easiest route will be to replace it with what it originally had, all these motors are available still.
