trans temp
Old Jan 9, 2011 | 11:46 AM
seth1's Avatar
seth1
trans temp
i noticed the other day when i was driving my truck the trans was only getting to 125 and this was after a 20 min warm up and a 40 min drive (outside temp around 0) on the way home home same drive, only got to 130. is there some sort of thermostat in there or something? what should the temp be running at after fully warmed up? i was usually sitting around 151. truck is 03 with 160k
Old Jan 9, 2011 | 11:48 AM
npccpartsman's Avatar
npccpartsman
There is an internal thermostat that's supposed to be a 165* but fairly difficult to change. It's possible it's a bad sensor, but with those cold temps.....
Old Jan 9, 2011 | 12:45 PM
seth1's Avatar
seth1
where is a good place to find some instructions on doing it? i guess my biggest concern is is it hard on the trans or anything not having it at operating temp?
Old Jan 9, 2011 | 01:26 PM
npccpartsman
IIRC the thermostat is in the pump, so it's a "major" repair. I'm not convinced it's the thermostat itself as much as the sender, which, IIRC, is problematic anyway.
Old Jan 9, 2011 | 01:40 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
with a aftermarket bra/cover/blanket im only up to 150 after a least 1/2 hr driving, in 0 degree weather. I don't think a cool tranny is a bad thing.
seth1's Avatar
seth1
hmm. i just remembered i did change a sensor for i believe temp in it already. a couple years ago while i was driving i noticed my trans temp guage was maxed out. i pulled over and checked fluid and it was good. my uncle did some research and tracked it to a possible sensor (cant remember what it was called) but i replaced it and it fixed the problem. do you think this would be the same sensor? it was just above the internal trans filter.
Old Jan 9, 2011 | 01:54 PM
npccpartsman
Just for grins and giggles, have you tried reading the temp. with a different gauge? I'm not convinced that you have a problem (except for the 0* outside temps--LOL). Brrrrrrrrrrr
Old Jan 9, 2011 | 03:19 PM
Jigger2020's Avatar
Jigger2020
Check the temp with a lazer pointing temp gun tool.
Old Jan 9, 2011 | 06:49 PM
seth1's Avatar
seth1
All I get is my edge insight. Just got it a month ago. I'll have to dig around and find my temp gun. So shouldn't be anything to be worried about?
Old Jan 9, 2011 | 08:19 PM
Jigger2020's Avatar
Jigger2020
Whats your ECT at when your tranny temp is low?
Old Jan 10, 2011 | 05:34 AM
seth1's Avatar
seth1
Around 185 and oil temp is around 195
Old Jan 10, 2011 | 09:01 AM
69cj's Avatar
69cj
With the outside temps and not towing it would take an hour or better to get much higher. I say your good to go and don't worry about it. Incidentally that sensor is the tft sensor.
Old Jan 10, 2011 | 07:10 PM
seth1's Avatar
seth1
i just talked to my buddy with the same truck and he said he is running about 160 to 165. im lost
Old Jan 10, 2011 | 07:21 PM
Misky6.0's Avatar
Misky6.0
In the morning, compare all 3 readings - they should be close together:
EOT, ECT, TFT. My TFT is always cooler in the AM than the ECT/EOT
- I would speculate because it doesn't get as hot during my commute
and thus cools off more than the ECT/EOT.
Normal ECT/EOT is 190+, while my TFT is rarely above 150.
I agree with the others, unless you tow or disable Overdrive,
your TFT won't get very high
Old Jan 10, 2011 | 07:23 PM
Jigger2020's Avatar
Jigger2020
Seth did you check it with your heat gun? Maybe just the sending unit
