Swapping front clips
Old Jan 9, 2011 | 01:37 AM
cs361's Avatar
cs361
I have a 76 f150 and a 79 f150. The 76 is my dads and the 79 is mine. He wants my front clip and I want his. My favorite style of truck is the 76-77. Can we just switch the whole front clips out? Or is this not possible?
Old Jan 9, 2011 | 01:42 AM
Riderman's Avatar
Riderman
Yes, absolutley possible, with no problems. I've done the exact swap you are asking about.
Old Jan 9, 2011 | 01:54 AM
Witty73's Avatar
Witty73
All you need to swap is grill shells, grill inserts, and headlight buckets.
Old Jan 9, 2011 | 02:07 AM
cs361's Avatar
cs361
Awesome! Its been my dream to have a 79 with a 76 or 77 front clip. Thank you both!
Old Jan 9, 2011 | 02:13 AM
Riderman's Avatar
Riderman
I thought the grill shell's were the same? I'm near certain they are. I didnt go into detail with my last post, like the fenders, etc were the same because the OP just asked about swapping a front clip, not pieces of a front clip. Mayby I coulda broke it down and explained the difference in parts better.
Old Jan 9, 2011 | 02:17 AM
Riderman's Avatar
Riderman
I put a 79 front end on my 76 in the eighties, I loved it then because it made the truck look newer. In the nineties, I changed the front end back to a 76, so it looks it's age.
Old Jan 9, 2011 | 02:44 AM
Witty73's Avatar
Witty73
79 grill insert is one piece, 76 is two piece.
Old Jan 9, 2011 | 09:20 AM
earthquake68's Avatar
earthquake68
Yeah, I've done this as well. You can just swap the grill shell, inserts, and headlight light buckets. The fenders and radiator support are the same. You'll probably have to pull the bumper to get at the lower bolts holding the grill shell in place. If you had a '78 with round lights, you wouldn't even need to change the headlight buckets. Just the grill shell and inserts.
Old Jan 9, 2011 | 09:28 AM
limegoldf100's Avatar
limegoldf100
You also need to swap the front bumpers. The 78-79 was a flatter style than the 64-77.
Old Jan 9, 2011 | 10:46 AM
cs361's Avatar
cs361
So what about the part that says FORD above the grille? Do you change that part too?
Old Jan 9, 2011 | 10:55 AM
impalaslayer's Avatar
impalaslayer
thats all one piece, the grille shell
Old Jan 9, 2011 | 11:05 AM
cs361's Avatar
cs361
Alright! And I didn't know you had to swap the bumper. Good to know.
Old Jan 9, 2011 | 11:09 AM
bigdaddys76's Avatar
bigdaddys76
One of you two is gonna end up with a funny looking truck because of the double F O R D
unless you are lucky enough to have the same color truck then just change the hood too.
Old Jan 9, 2011 | 11:14 AM
akforceten's Avatar
akforceten
All i did was to change to the 73-76 grille on my 78 bronco was bolt on a 73 -76 grille shell . as for the headlights i used 73-76 headlight buckets .i just had to drill the mounting holes for the headlight buckets here's a pic
Old Jan 9, 2011 | 11:16 AM
earthquake68
I think I pulled the letters out of the grill and left them on the hood when I did mine. I didn't even think about that until I closed the hood. .....DOH!
....or you could just say that you're REALLY proud of your Ford truck!
