Only 1 hazard light works
Old Jan 9, 2011 | 01:00 AM
mmhoward's Avatar
mmhoward
I swapped out my steering column today on my 95 F150. After I got it all put back together I was testing everything to make sure it all still worked. Got to the hazards and only the front passenger side one is flashing. On the dash only the right signal is flashing. All 4 signal lights work fine using the turn signals. The hazards worked fine before I yanked the column. Any idea what I screwed up? Is there something that might have come unplugged?
Old Jan 9, 2011 | 05:19 PM
mmhoward's Avatar
mmhoward
Any reason the multifunction switch might have gone bad while I had it apart?
Old Jan 30, 2011 | 11:07 PM
mmhoward's Avatar
mmhoward
Ended up being the blinker module. Not sure why it crapped out while I changed the steering column.
