General Diesel Discussion
Is this worth my time?
Old Jan 8, 2011 | 05:51 PM
twigsV10's Avatar
twigsV10
So my dad has a 91 chevy truck with a 350 that has no compression in #8 (cracked piston or ring). Can I pull a piston\connecting rod from my wifes 89 350 (same thing cracked piston) and put it in dads?
Old Jan 8, 2011 | 07:09 PM
Midwest Dually's Avatar
Midwest Dually
You would have to research rod diameter of the piston pin and crank hole. I am sure the length is the same, but getting that far up in the years.. you need research! Good luck
Old Jan 9, 2011 | 08:58 AM
senix's Avatar
senix
bore and stroke comparisons of each motor and then the specs on the piston and rod will tell you if they are a match.
Old Jan 9, 2011 | 01:25 PM
Maxium4x4's Avatar
Maxium4x4
First things first. Pull the block down to see how bad the cylinder wall is. As far as rods & pistons, GM small block parts are as cheap as a box of Chicklets.
Old Jan 18, 2011 | 10:20 AM
nitrogen's Avatar
nitrogen
two engines in your fam, both have cracked pistons. doesn't say much for the motors durability. if it cracked 1 are the other 7 far behind or are they going to come apart right after you start it, after the rebuild.
Jerry_D
Mar 7, 2015 02:33 AM
saleen065
Jul 8, 2008 09:06 PM
1978fordf250
Jul 30, 2007 09:53 PM
Blown 331
Feb 25, 2006 03:32 PM
78broncoman
Feb 12, 2004 09:55 AM
