How to get more power...
#61
That will work exactly the same way. All you've done is wire up a starter button that has totally bypassed the ignition switch.
#62
The DuraSparkII system takes a que from the 'I' terminal of the starter solenoid to retard the timing during cranking in order to relive the load on the starter itself.
It also provides a full 12V to the ignition coil for a hotter spark.
This gets dropped back to 7.5V +/- while running to keep the coil cool through the use of a resistor wire in the harness.
#63
Sounds like DSII is a lot better for my truck, then.
#64
I can't say "better", but it has features that are very good, and it is robust and simple enough to understand.
http://webpages.charter.net/1bad6t/duraspark.html
The same idea but going forwards instead of going "backwards" like you.
#65
Duraspark II
Duraspark II
Good link, saved it to my favorites.
#66
Sometimes the easiest way to do that is check around some of the 4x4 groups around you. I got my Ford 8.8 with 3.73 gears from someone that upgraded to D60 axles. Only cost me $50 and bolted right in.
#67
Besides, I'm 2wd. I'd like to find a matched pair of axles to go 4wd, but the ratio's are a bit more limited for me to stay with a 9". I just detest the stupid axle bearing design in the 8.8", and the fragile retainer bolt for the pinion gear center pin......
Brian Young II
07-18-2016 10:44 AM
6CylBill
Flathead V8 & Flathead 6
27
01-05-2012 02:59 PM
arkredneck
31
09-15-2007 11:28 AM
