Truck Decisions
1)Buy my truck back. Pretty decent buyout on a truck that I know the history of, and I know it has been trouble free for every mile thats on it...
2)Upgrade to a F250 6.2L gasser, same configuration/options as my current truck, +/- a couple
3)Upgrade to a F350 6.7L Diesel, same configuration/options as my current truck +/- a couple
Unsure of what to do. I could probably sell my truck for a decent profit, possible make 5-6g on it, which would go towards the new truck. On one hand, buying it back would be a cheap option, I've got extended warranty, and I'd have lots of money left in the funds. However, its a 3yr old truck, will have 80+k on it, when will it start to nickel and dime??
The F250/350 decision is an interesting one. The gasser is about 10g less than going with the diesel, but in 3 years what I would save in fuel (in theory if one can believe what is posted)would make up that 10g difference. Resale would be much better on the diesel, but maintenance would be a little more, and there's the extra 10g up front to consider.
What would you all do?
Honestly speaking though, I personally feel that with your plans to move back east, and my mind visioning that you will not live very far from a town or city out there (Is that accurate even?) I would do the superduty with the gas engine.
It sounds like you could use the configuration of a superduty, but I question the diesel part of it. Diesels are really great though, and I have had great luck with mine, but I also tend to do a fair amount of highway pulling, as well as a 20 minute drive to and from the city each time I take my truck.
Other problem I have with getting a 6.7 right off the bat... you guessed it, the first year of production.
Now gas vs diesel in a superduty...
Gasser is more practical for start and go, city driving and traffic, loaded or unloaded, pulling or not pulling.
Diesel will pull more, and better on the highway, and I would say at low speeds a little better, but not as noticeable.
The maintenance of a newer diesel vs a newer gas is the diesel oil changes cost more. I dont find them a problem on my old truck, as it just costs a bit of extra oil, but I assume on a newer one it would be costly.
How long are ya realistically gonna keep a new truck? If a long long time, I would say the diesel starts to look attractive. I just know you from on here, but you have had 3, maybe 4 primary trucks since Ive known ya, (NOTHING at all wrong with that either!) but that tells me your the kinda guy that wants a new truck every 2-4 years. That tells me that the new gasser would actually probably be better in resale value, cause in my experience, they still have decent resale value at that age.
Longterm a diesel has WAY more resale value though.
Now financially. No questions asked that the cheapest would be to keep your current truck. Now what I question, is will your f150 be able to do everything that you are gonna require it to do?
Nickel and diming.... sometimes man its cheaper to go that route as well. I can only relate my own experiences, but my trucks "nickels and dimes" although always a pain in the ***, are always cheaper then new truck payments. I just bought new upper and lower balljoints and u joits for the front end, and I think the total bill was 300 bucks, and labour is free if I can manage it.
Whew! what do you have in mind sherm?
Where we'll be living, building our home is about 1/2 hour drive from the city where I'll be doing the majority of my work. Thus it wouldn't be so much stop and go which I understand the diesel wouldn't be the best for that. If I were staying here, I'd probably just keep my current truck for quite some time. I really love this truck, and in this flat land, I could haul much larger trailers than I do with this truck. I'm planning on buying a much larger trailer for the move, + hoping to start a venture or 2 that I can continue to use the larger trailer. NL is a very hilly (small scale) mountainous area, my current truck would definately start to struggle towing heavy loads. Much of my towing work trailer will be highway, I've always enjoyed working away from home as the drive to and from the job is a time to relax.
Another reason I've been leaning towards the diesel, which is similar to the first reason I guess, is that the towing capacity of the Superduties with the 6.2 gas engine is only a few hundred lbs more than the F150/ecoboost. Right near that 12g range. We'll probably end up with a RV trailer somewhere along the line, and having the higher towing cap of the F350/diesel would expand the selection of RV's to choose from.
From the reading I've done, and peeps I've been able to talk to, the 6.7L diesel seems to be almost double the MPG when towing and a good 5-6 MPG more empty compared to the 6.2L gas engine.
Finally, I'm, hoping that this decision will be a long term committment, hence again leaning towards the diesel. If things go anywhere near planned or hoped, I will be expanding my business in the east, and definately have need for a larger truck. It would probably be easier and cheaper to purchase the truck here than back east.
I guess it seems like I've already made up my mind and have settled with the diesel. Its just a matter of seeing how it holds out for the next few months as it nears time to place my order...
Some other food for thought, the 2011 F150 with the Ecoboost engine is rated for a 11300lb towing capacity. The F250/gas engine is only rated for 12000lb with 3.73's, and 12500lb with 4.30's. The F350 gas is rated for 11900lb and 12500lb. The only difference I could see would be with 5th wheel towing where both superduties are rated for 15000lb with 4.30's. The F250/350 has a 2500(ish)/3800(ish) payload capacity while the F150/ecoboost is 1900(ish). Numbers taken from the Ford Superduty brochure and Ford.ca website.
I guess my point here is a person would be far better off with the F150/ecoboost than with the F250/gas, unless you do mostly heavy hauling in the box. The theoretical fuel mileage of the ecoboost would be far better than the 6.2L when empty for sure, and it would be interesting to see a comparison between the two for towing.
I suppose the more research I do, I've ruled out the 6.2L engine in any application and replaced it with the F150/ecoboost combo...
My truck is also rated for the 11,300lbs, and I find the 6speed trans really wakes up the 5.4l. I'm also interested in the new ecoboost, but thinking about a diesel for my next truck. My truck does a good job of pulling here on the flat but if we ever get a bigger fifth wheel or want to go to the mountains a diesel would be the right truck.
The '10 did get 18mpg on a trip to a rider game with five adults and cruise set at 130kl.
From whay Ive seen on the 150's, they are a much better truck than the SD. I wouldnt hesitate to go with a 150 and use air bags - this would meet most guys requirements! Ford rested on their laurels with the SD, battled engine suppliers and emissions, and is now at the bottom of the heavy truck segment in my opinion!
An interesting thing after talking to the service manager at the local dealer, He's had 3 trucks from '04-'08, all CC/4x4/SB/5.4L, 3.73 rear gearing. He said each truck has been totally different in how they drive, mpg, and just the "feeling" in general. One would flat out smoke the tires from a dead start, one can't turn them to save a life...
I will consider the F150/Ecoboost combo, but again, its fairly new technology as far as I know, really new for a truck application!! I had air bags on my '02 SuperCrew and it was amazing the difference in ride quality and load handling. Properly loaded, I could load that truck way beyond the manufacturers specs, and still drive in a safe manner...meaning the front end still touched the ground...
