2001 f350 no start
Old Jan 7, 2011 | 06:09 PM
tortster's Avatar
tortster
Unhappy 2001 f350 no start
I have an ongoing problem of no start, but will with starting fluid. I've read a lot here and done a lot of trouble shooting. I am getting fuel shooting out of the drain, wires/connectors and fuses, all look good. when it started with starting fluid, i got no oil pressure on gauge in short run. So i figure its the oil pressure safety switch/sending unit. Any one know where it is located? Also, i don't get any codes on it.
Old Jan 7, 2011 | 06:13 PM
spdmpo's Avatar
spdmpo
More info. Does it always no start, or once it's been warmed up it starts ok the rest of the day? When it does start does it run ok after? Start here:
https://www.ford-trucks.com/forums/1...ky-thread.html
Old Jan 7, 2011 | 07:05 PM
tortster's Avatar
tortster
Started the other morning for about 30 sec, died and didn't start back up. Now it doesn't start at all. It is plugged in and warm.
Old Jan 7, 2011 | 07:12 PM
F350-6's Avatar
F350-6
The oil pressure gauge is just an idiot gauge. It doesn't really tell you much.
When you turn the key on, does the WTS (wait to start) light come on for a few seconds then go off? When you try and crank it, is there any smoke coming out the tailpipe while cranking? If so, light or heavy smoke, and what color?
When was your last oil change? Is the oil still full? What oil are you using? Have you checked the oil level in your HPOP reservoir? How many miles on the truck? Are there any modifications to it (chips, tuners, etc.)?
Old Jan 7, 2011 | 07:30 PM
tortster's Avatar
tortster
WTS works, cranks, no smoke, 1000 mi on oil (delo), no mods, 250k. I couldn't open the plug but pulled sensor on other side and it was empty, what if its empty?
Old Jan 7, 2011 | 07:44 PM
F350-6's Avatar
F350-6
Originally Posted by tortster
what if its empty?
Fill it up to within an inch of the top with some Delo and see if it starts then. If it does, see if it drains down again.
Also while you're poking around, check to make sure the nut didn't fall off the back of the IPR or make sure the wiring to the IPR isn't burnt or chaffed.
Old Jan 7, 2011 | 08:21 PM
tortster's Avatar
tortster
Didn't start. IPR and wires look ok.
Old Jan 7, 2011 | 08:29 PM
F350-6's Avatar
F350-6
So the reservoir was empty, you filled it up and tried to start? Is it empty again or did it stay full? Did it smoke any while cranking or act or sound any different for a second or two with oil in the reservoir?
Old Jan 7, 2011 | 08:39 PM
firestroker8706's Avatar
firestroker8706
I'm no expert by any means, but I'll throw my .02 in. I'm a basics kinda guy, so my first thought would be to check the oil level. If it's low, that would cause a no start.(ask me how I know that) Then I would check the CPS. I had the same issue as you, my truck would start and run for 30 seconds, then die. I eventually replaced the CPS and she fired right up, no problems since. Just be sure not to crank on it to long before you replace the CPS, you could fry the starter. (Again, ask me how I know that) After that, I useless. I don't know if you have done this stuff or not, but I figure that someone should state the little stuff just in case.
Old Jan 8, 2011 | 12:47 AM
bluescrew's Avatar
bluescrew
have you tested your gpr
Old Jan 8, 2011 | 08:36 AM
Kwikkordead's Avatar
Kwikkordead
Subscribing.
Old Jan 8, 2011 | 10:49 AM
lostmybeer's Avatar
lostmybeer
Have a nice Beer!!!
I'm a subscriber too.... just out of curiosity, are you able to check your ICP and IPR Duty cycle? Also, do you have a volt meter to read what the batteries are doing? Is your GPR working as mentioned before?
Old Jan 8, 2011 | 07:04 PM
tortster's Avatar
tortster
HPOP stayed full, batts are dead will get more tomarrow.
Old Jan 11, 2011 | 03:12 PM
tortster's Avatar
tortster
spdmpo says "The oil pressure gauge is just an idiot gauge. It doesn't really tell you much." Well it obviously does. The batteries were good. The starter was good. The pressure gauge didn't go up and it seized the motor while turning it over. Anyone out there know if the pressure gauge works while turning it over?
Old Jan 11, 2011 | 03:39 PM
tdpower's Avatar
tdpower
On mine the oil gauge doesn't register until after it starts. If the engine locked up it might be hydrolocked. Probably from a bad injector dumping into the cylinder. You can pull the glow plugs and see which cylinder has fluid in it.
