Old Jan 7, 2011 | 05:24 PM
tortster's Avatar
tortster
Unhappy 2001 7.3
I have an ongoing problem of no start, but will with starting fluid. I've read a lot here and done a lot of trouble shooting. It seems i am not getting the fuel to start and run. when it started with ether i got no oil pressure on gauge. So i figure its the oil pressure safety switch. Any one know where it is located? Also i don't get any codes on it.
Old Jan 7, 2011 | 05:36 PM
orng1's Avatar
orng1
Post in the 99-03 7.3 section for better help.
Do you get any smoke out of the exhaust while cranking?
Old Jan 7, 2011 | 05:55 PM
tortster's Avatar
tortster
no, I'm not getting fuel.
Old Jan 7, 2011 | 09:53 PM
powerstroke72's Avatar
powerstroke72
Moved to the 1999 - 2003 7.3L Power Stroke Diesel forum.
Old Jan 7, 2011 | 09:56 PM
timmyboy76's Avatar
timmyboy76
i'm no mechanic for diesels, but i'd check, first to see if the fuel pump is run'n, with key to on. Next, i'd pull the in bowl fuel filter, see if thats full of fuel, then i'd remove the "check plug" on top of the hpop, make sure that has oil up to about 1/2in from plug.
Old Jan 7, 2011 | 09:57 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
First, stop using ether unless you want to put a new engine in. Second, if your not getting white smoke while cranking check your HPOP resi for oil and if you have a scan tool check your IPR. Also make sure your fuel pump is coming on. Very good chance its one of those two.
