466 combo
466 combo
After months of going back and forth on my engine build i finally have decided on eagle crank and rods , Comp cams xtreme 4x4 262H cam, Edelbrock RPM intake manifold and aluminum RPM 95cc heads and holly street avenger carb 770cfm, and more than likely SRP pistons and want to come in somewhere between 9.5.1 to 10.0.1 compression. It will be going in a 93 F-250 2wd regular cab with 3.55 gears and i am thinking of using the money i would of spent on a fuel injection system and buy a tremec TKO 5spd or 6spd with adapter. I was wanting to know others opinions on if this is a good combo and what kind of power could i expect from this motor, this will be my first stab at building a big block and i want to get it right
The SRP pistons with those heads should put you right at 9.5:1. Only question I have is why you are swapping out the crank too? The stock 460 crank will handle everything that buildup is going to put out. Other than that, I think you will be plenty happy with that setup
Comp has by appearance - seems to be a company that has experience more cam lobe failures than most and places the blame on the low ZDDP in the oils. Is it a factor yes, but I highly suspect that they are also using Chinese cam billets & they do not include Parkerizing their cams (Parkerizing is the final step and a crucial step to help break the cam in- a heated acid bath that microscopically etches the metal surface and adds a very thin layer of graphite coating which allows the cam lube to hang onto and penetrate into the cam surface during cam break in) unless you specifically request and pay additional money for it.
Considering the cam has such critical importance to the engines performance and life, to me it makes sense to use a cam grinder who will talk with you directly- even modify the cam grind to fit your needs even better and to address the possibility of cam lobe failure with the new oils. Advertized lift/duration/lobe separation is just that- advertized and not the specific grind including ramp profile that is used on the cam. That is why I highly recommend Iskenderian & Crower...both are family owned, been grinding cams for decades, and both will even re-grind your oem cam if possible- saving you even more $.
As you are probably aware, many of the cam mfgs in the past few years either sold, closed their operations to re-open elsewhere (typically with new staff) or .......In addition to Isky & Crower, I use to very highly recommend....Sig Erson & Crane...Both became part of corporate entities, eventually leading to periodic quality issues and closing their doors- I think Crane re-opened, but with a different staff. Typically the staff is very, very young and well- requires a learning curve.
If you do a search on the net, Harvey Crane has posted a little summary of the history of the people who made the cams at Crane, his opinion of what happened and the eventual outcome of several of the staff. When it comes to making an engine breathe, there are so many variable including elevation, humidity, fuel blends/available octane, most cam mfgs will vary a "core grind pattern" to match the external impactors in addition to the internal impactors- which today IMHO makes the different between and engine that runs well, to one that just seems to run a little bit better, smoother and gets better mileage than expected.
Ummm, Phosphate coating.
Graphite would never hold up to those pressures.
DLC (diamond like carbon) would and IT is a graphite process, but it is so slick the break in lube would not stay on the lobes, and the lifters would wear first. (works good on piston skirts though)
What Is Parkerizing
Diamond coating diamond like carbon DLC and ta-C
(Not trying to start an argument, just trying to clear the air)
What Is Parkerizing
.... I highly suspect that they are also using Chinese cam billets & they do not include Parkerizing their cams (Parkerizing is the final step and a crucial step to help break the cam in- a heated acid bath that microscopically etches the metal surface and adds a very thin layer of graphite coating which allows the cam lube to hang onto and penetrate into the cam surface during cam break in) unless you specifically request and pay additional money for it......
Beechkid, that is at least the second time you have posted that copy and past article on FTE. With a 5 second google search I find it posted word for word on other web sites. So it is NOT just you talking you have taken an article from somewhere and it needs to be linked to show where your getting your info and so people can make the decison on informed information not mis-information or propaganda by someone with an ax to grind.
And it IS full of mis-information. first comp isn't having any more percentage of failures then anyone else.
Parkerizing is what the military does to its weapons, my M-1 and M1911A1 are both parkerized and its a durable coating for firearms, i did not know they did that to cams ?.
68 murc youre truck looks incredible, do you have any links to video of your truck running?
And L Ward youre right i could save money on the crank i just figured having a machine shop go over my stock crank and a new one from eagle would be about the same price.
How well do think my truck will drive with a TKO 5spd or 6 spd instead of the low geared granny 5pd thats in there now and the 3.55 gears
Yes, they do that to cams.
The military doesn't do too much Parkerizing any more.
Companies like Robar specialize in advanced coatings and finishes for firearms and artillery pieces that are far more effective than 1920's technology.
and the mis-information is rampant in tooI highly suspect that they are also using Chinese cam billets & they do not include Parkerizing their cams (Parkerizing is the final step and a crucial step to help break the cam in- a heated acid bath that microscopically etches the metal surface and adds a very thin layer of graphite coating which allows the cam lube to hang onto and penetrate into the cam surface during cam break in) unless you specifically request and pay additional money for it.
All Billet cams are OEM Spec cold chilled cast billet units that are ground in 3 stages to the final specs on Colt Cams Van-Norman/Berko machines (known in the industry as superior cam grinding machines). All cams are rough cut, checked and restraightened (if necessary), then medium cut to within 3 thousandths, checked and then final cut to within 1 thousandths prior to final prep and parkerizing. Parkerizing is the final step that some big name cam companies will not even offer, and a crucial step to help break the cam in (a heated acid bath that microscopically etches the metal surface and adds a very thin layer of graphite coating which allows the cam lube to hang onto and penetrate into the cam surface during cam break in).
PDM Racing - Cam Corner
The Parkerizing is a protective coating used on cams and sometimes lifters that disappears a few seconds after startup. This coating is deposited in an acid solution that slightly degrades the finish on the lifter foot. According to Stanadyne, they have made no change in their lifter manufacturing procedures or materials.
Chrysler Corp. stopped Parkerizing all their cams many years ago when they discovered this degradation of the surface finish actually contributed to cam failures in their 2.2L OHC engines.
Almost all domestic camshaft castings come from the CWC foundry in Muskegon, MI. The heat-treating is done at the foundry. While there can be several different casting patterns used for each engine, the material is usually identical except for the P55 castings. The heat-treating is also identical. There have been no changes at CWC or at their customers supplying semi-finished castings to the performance market other than some increased automation. About the only significant difference in the castings is the lobe width, with wider lobes offering greater load carrying ability.
CamCraft Cams - Cam Failures: Some thoughts on cam and lifter wear
FWIW, I have installed many comp camshafts, and have had a total of THREE failures.
- 460 BB, 278/288 Xtreme 4x4, lobe failure early on when the oils issue wasn't really known yet. Comp sent a new one out (with lifters).
- 400 Chevy, treated with additives, but not driven much. Lobe failure, Comp offered to send a new one out, instead we had them credit towards a custom roller grind camshaft.
- 460 BB, snapped the dowel pin off when the motor locked up at 5000rpm (bearing failure on a rod) Not comps fault. Machined a new dowel pin, and put it in a beater motor.
Also, personally I would never advise re-grinding an OEM or old cam. With the cost of a new cam, the couple $$ saved is not worth it. Years ago it was a good way to get a custom cam, but with todays costs, even a custom grind is not that hard, and you don't have to worry about whether or not the core can handle it.
Other than the shifter length, on a 2wd with stock height tires it should be plenty impressive! Add in a set of 3.73s or 4.11s and it will be brutal out the gate (if you can keep traction, LOL)
77custom408, First, thanks for the compliment.
I do have video of my truck running, and at the track. I have no idea how to get it on here though.
Also, I've got a C6 w/ 2200 stall behind my 460 and 3.25 gears. It still launches well (breaks tires loose) but with some better gears like mentioned above, and stickier tires, it would really get up and go.
I'm keeping the gears for now because I've only ever been to the track once and don't plan on using the truck for the track. I've got to get some gas mileage out of it somehow.
Stainless is by far my favorite but i prefer to keep them in their 1940's condition
I would never suggest you refinish a classic firearm in NP3 or anything like that.
I was just saying that even though my Garand and 30 Carbine are parkerized there are better coatings available to the military today.
My truck works great on the street. In three years of almost daily summer driving, I've never had any problems. The engine has just a bit of a lope at idle at 850RPM.
I used a dyno program when I was building my engine, and it came up with 440HP and 510FT/LBS. I know it's not 100% accurate, but I'd bet I'm not too far off.
One thing I've noticed though is the new stock valve springs start to float around 5000RPM, so I don't rev it past there. If your new heads came with better springs you shouldn't have any problems.
I've always wondered what my truck would be like with a manual trans. I'm sure it would be a blast.
What Is Parkerizing
What Is Parkerizing
