Simple Lift
Old Jan 6, 2011 | 05:53 PM
Ziegelsteinfaust's Avatar
Ziegelsteinfaust
Simple Lift
Well for no explaned reason I decided that I want to lift my 66 F-100.
I am thinking a simple 2 inch lift and have the beams cold bent to compensate. I know beyond that "3" or more" I will have to spend more money then I want too, but I believe I have heard from people 2" is ok with a bend to compensate.
Autofab says stock radius arms and steering is ok with the 3" budget lift so obviously it will be ok at 2".
What do you guys think?
Old Jan 6, 2011 | 06:54 PM
Ziegelsteinfaust
What about a body lift?
Any body ever use one of these?
Old Jan 6, 2011 | 08:15 PM
Bill W's Avatar
Bill W
I want to do the same thing but i want the 5 inch lift kit autofab offers so i can go do this!
Old Jan 6, 2011 | 08:22 PM
Bill W's Avatar
Bill W
I think the econo 3 inch lift is well worth the money
Going this far with a truck is out of the budget for me... but a truck like this would be nice!
Old Jan 6, 2011 | 08:25 PM
Bill W's Avatar
Bill W
OR.... how about a bump side? Can you tell i want an Off road truck? lol
Old Jan 7, 2011 | 12:17 AM
garbz2's Avatar
garbz2
Bill,
That red truck is BADD! Looks like it is using 80 spindles with ball joints.
"Christine" reincarnate! with a 410 stump puller.
Garbz
Old Jan 7, 2011 | 12:56 AM
Bdox's Avatar
Bdox
Just say NO to body lifts!
Old Jan 7, 2011 | 10:37 AM
nairod's Avatar
nairod
Why "no" to body lifts? Seems like 2" would be simple and cheap. A guy could really easily just weld up some 2" blocks. I guess the wiring would still reach the stuff in the engine bay.
I don't know if the steering hook up or speedo would be a problem. I looked at doing this on my 76 and don't remember having a concern.
If you're fussy, rig some skirts for the frame to fender well gaps and you're in business for your labor and hardly any money.
I also considered spacing the twin I-beam mounts 2" from the frame and adding the spacers between the springs and axle. That didn't seem very hard, technically, either, plus it would have given me an excuse to replace all the bushings.
I finally decided that with a 2wd, open diff, heavy truck, making it all show and no go wasn't worth the trouble.
Old Jan 7, 2011 | 11:40 AM
Bdox's Avatar
Bdox
Body lifts are all show.
Old Jan 7, 2011 | 12:21 PM
Ziegelsteinfaust
All show is fine with me I don't wanna jump the truck like its the world series or anything.
I just wanna clear some taller tires.
Ziegelsteinfaust
How about a bit of a spring lift?
Old Jan 8, 2011 | 02:08 AM
garbz2's Avatar
garbz2
Body lifts are illegal in most states. All depends where you are. John Law can make your life miserable.
A extension for the springs will lift the front and are simple to make, but will still require the beams to be adjusted for camber. And the rear leafs can be re arched for added lift.
Garbz
Old Jan 8, 2011 | 10:34 AM
bertha66's Avatar
bertha66
I got a 2" lift for my Bronco off of E-bay. They are blocks that go under the coil springs, witha extendion for the stud that holds the spring to the axle. I did have the ajust the chamber after. The rear can be done by making blocks for the springs with longer U bolts
Old Jan 8, 2011 | 11:23 AM
garbz2's Avatar
garbz2
Camber is non adjustable and pre set on a front drive axle on a bronco untill you get in to the Twin in 80 like yours.
Caster is what gets whacked on earlier axles and there are polyurethane degree bushings for correcting this on 66 to 77s and 78/79s. F100 and F150 four wheel drives also. It will also be out on the 80 up if a relocation bracket was not added to the radius rod.
Unfortunately the 2 wheel drive Twin I must be bent to correct any lift or drop if using the stock brackets.
Garbz
Old Jan 8, 2011 | 11:16 PM
nairod's Avatar
nairod
I still think a guy could de-rivet the front suspension mounts from the frame and fab 2" spacers. The idler arm would have to be modified, too, I guess. Then camber, caster all stay the same.
Put 2" blocks between the rear axle and the springs (they make them already angled for proper drive train alignment) and you're done.
